|  | Home > Technical (L322) > TDV8 2010 Top Rad Hose 4 Way Coupling - Please Help Identify |
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276      | No idea sorry, but http://cat.lrparts.ru will have it. | ||
|  3rd Sep 2018 7:54pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | Only available as a complete unit including hoses I believe, mine broke in exactly the same place - I tapped a thread in the exposed hole after cutting the remaing bits of the joint flush, theres enough meat in the main section, then screwed in a metal joining pipe for the small plastic hose to push on to, not leaked since   | ||
|  3rd Sep 2018 7:56pm |
| Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410    |
 That site doesn't open for me.
 I thought of that, but it'd take a day in the plumbing shop to identify the right little jobby to screw in the void. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 2006 Bentley Flying Spur in silver | ||
|  3rd Sep 2018 8:10pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Part no depends on your vin, but mine is
|  3rd Sep 2018 8:28pm |
| Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410    | Thanks for that, yes indeed it's that. Eighty odd quid as you must buy the hoses with it. I'm not liking the idea of £80 to replace a tiny bit of snapped plastic. I think I'll repair it as JCW suggested.
|  3rd Sep 2018 8:35pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | I opened the hole out to around 8mm, tapped a thread, then used a female to female co-ax plug (as you'd use for aerial wiring) with the plastic insert removed (drilled out) - its what I had floating around in my tool box, has the same internal diameter as the smaller pipe, had threads on each end and fitted perfectly! I applied some araldite to the threads before screwing it in / pressing the small pipe back on.
|  4th Sep 2018 5:59am |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | Great fix  JCW, thanks for sharing.
|  4th Sep 2018 8:00am |
| Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410    | I didn't have aerial connectors or taps handy so I did it another way. I'll share it here as it may help others.
|  4th Sep 2018 4:08pm |
|  4th Sep 2018 4:58pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | looks like a decent fix.
|  4th Sep 2018 5:02pm |
 I actually prefer your method as the threads prevent the two parts separating (belt and braces). Araldite is an unknown element with prolonged heat here. But as the original seems so flimsy and has lasted eight years, I'm hopeful mine may last longer. Do we need to bleed the cooling system on these please does someone know? Or just top up the tank and let any air work through? It never lost enough water to overheat. I'm leaving it overnight to let the glue go off anyway. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 2006 Bentley Flying Spur in silver Last edited by Stuart- on 4th Sep 2018 5:42pm. Edited 1 time in total | ||
|  4th Sep 2018 5:31pm |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965    | Yes bleeding is required, undo the plastic screw a little on the top hose (near the expansion tank) and with the engine running, leave open until it stops bubbling. I wrapped the pipe with a small towel to stop the coolant dribbling down into the front of the engine bay - I believe its not a good idea for coolant (antifreeze) to come into contact with paintwork. | ||
|  4th Sep 2018 5:36pm |
| Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410    | Super, thank you. Final bit of the fix there for the enthusiastic amateur.
|  4th Sep 2018 5:49pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277      |
 Me being a pedant.    John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold | ||
|  4th Sep 2018 6:43pm |
| Posting Rules
