Home > Technical (L322) > TDV8 2010 Top Rad Hose 4 Way Coupling - Please Help Identify
Stuart-
2010 TDV8 4.4.
I was out this evening and a coupling on top of the engine inexplicably broke and water was everywhere. Dash lit up like an Xmas tree, etc. On opening the bonnet the culprit was easily visible right on top. Took frequent stops and 9 litres of water to get home.
Some light Googling isnt yet showing me a reliable engine diagram or parts list. Can anyone point me towards a resource with a decent exploded drawing and/or look up a part number for that coupling please? The one with top hose in and out and a small pipe off each side.
Hoping to try the main stealer tomorrow if they have one in, if not I'll order online with next day delivery from somewhere. So a part number would be really handy. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
Post #487909 3rd Sep 2018 8:45pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
No idea sorry, but http://cat.lrparts.ru will have it.
Post #487911 3rd Sep 2018 8:54pm
JCW
Only available as a complete unit including hoses I believe, mine broke in exactly the same place - I tapped a thread in the exposed hole after cutting the remaing bits of the joint flush, theres enough meat in the main section, then screwed in a metal joining pipe for the small plastic hose to push on to, not leaked since Thumbs Up
Post #487912 3rd Sep 2018 8:56pm
Stuart-
That site doesn't open for me.
I thought of that, but it'd take a day in the plumbing shop to identify the right little jobby to screw in the void. 2017 4.4 SDV8 Autobiography in black
Post #487915 3rd Sep 2018 9:10pm
Part no depends on your vin, but mine is
LR029140 as far as I can tell.
Will be LR only so if you give your local parts department a call they will be able to find it. There is nothing that can't be fixed with a hammer😜😜
Post #487917 3rd Sep 2018 9:28pm
Stuart-
Thanks for that, yes indeed it's that. Eighty odd quid as you must buy the hoses with it. I'm not liking the idea of £80 to replace a tiny bit of snapped plastic. I think I'll repair it as JCW suggested.
So it's either an internal stent Araldited in, or a screw in self tapping jobby.
JCW, can you point me towards what you used, please? 2017 4.4 SDV8 Autobiography in black
Post #487918 3rd Sep 2018 9:35pm
JCW
I opened the hole out to around 8mm, tapped a thread, then used a female to female co-ax plug (as you'd use for aerial wiring) with the plastic insert removed (drilled out) - its what I had floating around in my tool box, has the same internal diameter as the smaller pipe, had threads on each end and fitted perfectly! I applied some araldite to the threads before screwing it in / pressing the small pipe back on.
Here's a picture of the plug - less than a quid opposed £80.
Post #487950 4th Sep 2018 6:59am
Baltic Blue
Great fix JCW, thanks for sharing.
I have a set of these drill/taps which will be great if ever I need to do the repair.
It’s the sort of problem I dread happening whilst touring Europe on my holidays.
Post #487953 4th Sep 2018 9:00am
Stuart-
I didn't have aerial connectors or taps handy so I did it another way. I'll share it here as it may help others.
As I have a couple of stents I reckon a stent would work. The joint doesn't seem under a great deal of pressure, so I'm hopeful it will last.
Here's the broken bit:
I cleaned it out a tad by hand with a drill bit to get the bits of smeg out and key inside the holes.
Here is a small piece of brake pipe which is the perfect size as a stent. Clean it up with a file or a bit of sandpaper so it will key and chamfer the ends a tad.
Clean the insides of the pipes and the break area up with meths or similar and a cotton bud. Dry it off with a hairdryer so its bone dry and also the plastic will expand a tad.
Araldite one half of your stent up and twist it in with long nose pliers. Araldite the other side of your stent up now.
Hold it in place with the long nose pliers while you offer the pipe up to it so you know the stent is about 50/50 in each side, then slide it nicely home as you remove the long noses.
Looks alright to me and no £80 going on. Takes less than ten minutes. Thumbs Up
If it fails I'll use JCW's method instead. 2017 4.4 SDV8 Autobiography in black
Post #487990 4th Sep 2018 5:08pm
JCW
Thumbs Up basically the same approach, sure it'll be fine - actually more robust than the original connection!
Post #488002 4th Sep 2018 5:58pm
looks like a decent fix.
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #488003 4th Sep 2018 6:02pm
Stuart-
I actually prefer your method as the threads prevent the two parts separating (belt and braces). Araldite is an unknown element with prolonged heat here. But as the original seems so flimsy and has lasted eight years, I'm hopeful mine may last longer.
Do we need to bleed the cooling system on these please does someone know? Or just top up the tank and let any air work through? It never lost enough water to overheat.
I'm leaving it overnight to let the glue go off anyway. 2017 4.4 SDV8 Autobiography in black
Post #488005 4th Sep 2018 6:31pm
JCW
Yes bleeding is required, undo the plastic screw a little on the top hose (near the expansion tank) and with the engine running, leave open until it stops bubbling. I wrapped the pipe with a small towel to stop the coolant dribbling down into the front of the engine bay - I believe its not a good idea for coolant (antifreeze) to come into contact with paintwork.
Post #488006 4th Sep 2018 6:36pm
Stuart-
Super, thank you. Final bit of the fix there for the enthusiastic amateur.
Between us this topic is an excellent "how to" to save members £80+ each on a new hose assembly.
From Googling, this seems a very popular item to fail. I'm surprised one of the parts specialists haven't made the coupling after-market if demand exists. We make appliance parts and are not averse to car parts. I have an explanatory article >>here<< and would welcome input from the repair trade there on this specific part. 2017 4.4 SDV8 Autobiography in black
Post #488008 4th Sep 2018 6:49pm
Weegie
JCW wrote:
I opened the hole out to around 8mm, tapped a thread, then used a female to female Question co-ax plug (as you'd use for aerial wiring)
Me being a pedant. Embarassed Very Happy John
GAP iiD BT-Sold
Post #488010 4th Sep 2018 7:43pm
