![]() | Home > Technical (L322) > Coolant amount |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Hi Guys
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35738 ![]() ![]() |
re-fill is 13 litres and from dry is 17.3 litres... ... - .- -.
Bloody hell! That's quite alot. Will draining for doing the rad be a full refil aka 17L or 13L? |
should be 13 litres but it might be worth getting a bit more just in case... ... - .- -.
Might be a stupid question but a 50/50'mix? Normal tap water? |
yep, 50/50 mix..
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1526 ![]() ![]() |
I'd suggest de-ionised water it's only cheap and no mineral deposits. |
![]() Y. O. L. O. . |
Reds not that expensive, or you can change to blue. Make sure you do a full flush though. BMW has noted issues with the OAT coolant causing problems with the plastics they use in the cooling system. |
btw rob , all this info is on the wiki.. ... - .- -.
Thanks guys. Where can I get de-ironised water from? To do a flush what would be required?
europarts for the water, £4 for 5 litres ...as for the total flush , i suppose a hose pipe in one end and wait for the water to come out the other... ... - .- -.
Would that surfice or would it have to be warm? Would that get round all the channels in the block? |
dunno rob, i've only done it on a fiesta with no problems ,never done it on the range but i'm sure someone will come along and say.. ... - .- -.
