Home > Technical (L322) > Coolant amount
Coolant amount
Hi Guys
Just in the woods walking the dog so have restricted access to stuff. Changing my rad tomorrow so need/want new coolant. It's a 4.4 V8 petrol. What's the total amount needed? Unfortunatly it's the expensive red stuff. Damn!
Thanks
Rob
Post #48809 4th Feb 2011 5:55pm
re-fill is 13 litres and from dry is 17.3 litres... ... - .- -.
Post #48813 4th Feb 2011 6:17pm
Bloody hell! That's quite alot. Will draining for doing the rad be a full refil aka 17L or 13L?
Post #48817 4th Feb 2011 6:39pm
should be 13 litres but it might be worth getting a bit more just in case... ... - .- -.
Post #48822 4th Feb 2011 6:50pm
Might be a stupid question but a 50/50'mix? Normal tap water?
Post #48825 4th Feb 2011 6:54pm
yep, 50/50 mix..
surprisingly the td6 takes only 11 litres for a re-fill.... ... - .- -.
Post #48826 4th Feb 2011 6:56pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I'd suggest de-ionised water it's only cheap and no mineral deposits.
Post #48827 4th Feb 2011 6:58pm
Thumbs Up ... - .- -.
Post #48829 4th Feb 2011 7:02pm
dan_uk_1984
Reds not that expensive, or you can change to blue. Make sure you do a full flush though. BMW has noted issues with the OAT coolant causing problems with the plastics they use in the cooling system.
Post #48830 4th Feb 2011 7:19pm
btw rob , all this info is on the wiki.. ... - .- -.
Post #48837 4th Feb 2011 7:39pm
Thanks guys. Where can I get de-ironised water from? To do a flush what would be required?
I didn't get round to the wiki but did try a search whilst out with the dog but wasn't that easy in the woods and on my iPhone.
Post #48852 4th Feb 2011 8:25pm
europarts for the water, £4 for 5 litres ...as for the total flush , i suppose a hose pipe in one end and wait for the water to come out the other... ... - .- -.
Post #48853 4th Feb 2011 8:32pm
Would that surfice or would it have to be warm? Would that get round all the channels in the block?
Post #48857 4th Feb 2011 9:26pm
dunno rob, i've only done it on a fiesta with no problems ,never done it on the range but i'm sure someone will come along and say.. ... - .- -.
Post #48858 4th Feb 2011 9:33pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
mabe do a drain then 100% water up to temp then drain again.
I like what i have read about the oat pink stuff. 2004 black Vogue TD6
Post #48865 4th Feb 2011 10:29pm
