![]() | Home > Technical (L322) > Headlight wiper relay |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
This any use to you?
| Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180
Thanks
A bit of an update
| Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120
Sure I read somewhere on here about the Motors being Powered via the Rear Washer Pump.
I think you mean the wipers also run the headlight washer pump which if seized trip the BCU and stop the wipers from working correctly, which needs fuse 28 to be pulled to reset.
