![]() | Home > Technical (L322) > Headlight wiper relay |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
This any use to you?
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
Thanks
A bit of an update
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Sure I read somewhere on here about the Motors being Powered via the Rear Washer Pump.
I think you mean the wipers also run the headlight washer pump which if seized trip the BCU and stop the wipers from working correctly, which needs fuse 28 to be pulled to reset.
