Home > Maintenance & Mods (L322) > Deployable side steps
Page 2 of 3 <123>
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
just be my luck I'd Censored a bit that cant be repaired ! still a cracking addition to an FF though
Post #450754 12th Sep 2017 9:41pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Ive a broken bracket on the passenger side on one of the arms but not looked at it yet properly i know its cast but not sure of the metal to see how to repair or if it can weld _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #450906 14th Sep 2017 12:08pm
Lester Burnham
Dear all, I fancy these for my forthcoming 09 Autobiagraphy. It currently has the fixed rubber variety which I really dont like the look of.
Seen some new original deployable sets at circa £400 on Ebay, has anyone fitted these and do they come with all the bits needed? The picture shows some very exposed looking motors and actuators! Hard to believe there shouldnt be some kind of cover or gaiter for these...
Post #489090 17th Sep 2018 12:29pm
have a look in our wiki, there are a couple of how to's in there..
Post #489092 17th Sep 2018 12:32pm
j_rov
@Lester, the motors are sealed enough to cope with "normal" driving. All cabling and access to cabin is adequate too. They are actually very well made.
If you are intending to be driving through mud or sill level water often, they may not be for you...
I got the full kit off Duckworths on here for less than £400. There's 2 versions, but you'd have the same as mine since which was that price. The kit you show in your photo is incomplete. There's an ECU and wiring loom(s) also.
Fitting is a bit awkward but easily done on your own. Little scary how much of the interior has to come off, but all easy stuff.
I also recommend mud flaps to reduce the road crud hitting the steps. They get dirty very quickly without. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #489093 17th Sep 2018 12:45pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
When I upgrade its a must to have or fit asap would not be without
Post #489177 17th Sep 2018 10:27pm
Lester Burnham
Cheers all. Not intending to be a mud plugger, but will take the advice about retaining front mud flaps.
Post #489180 17th Sep 2018 10:57pm
kooky_guy
I've just replaced my fixed ones with these and am really pleased. The fixed ones had literally crumbled away to dust and actually broke when my wife stood on them (bit odd as the paperwork with the car suggests they were only 3 years old).
The deployables seem wider and nicer to use than the fixed ones. I probably will do some light off roading so will have to be careful with them! 2010 4.4 TDV8 Vogue SE
Post #489190 18th Sep 2018 7:43am
Yes they were fitted by me 3 yrs ago... Just goes to show how well they age!!! Rolling Eyes Shocked
Post #489245 18th Sep 2018 6:13pm
kooky_guy
Wow Craig! They were literally collapsing under their own weight! Looked older than the car!
Good old LR quality! 2010 4.4 TDV8 Vogue SE
Post #489257 18th Sep 2018 8:13pm
Indeed sir Rolling Eyes ...
Post #489267 18th Sep 2018 10:38pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
I'm thinking of changing my rusty old fixed side steps for deployables,mine have been on since the car was new and it's a 2009 model so can't complain about them being rusty really.My question is do the deployable steps use the same holes that the old fixed ones use? And if they do I'm hoping the bolts will come out and leave nice clean bolt holes for the new steps. 2009 Vogue SE Zermatt silver
Post #489275 19th Sep 2018 2:42am
kooky_guy
Mine did. Soak them in plus gas or something equivalent first though!
The walk through in the wiki suggests that you might want to retap them to clear the threads but I didn't need to. 2010 4.4 TDV8 Vogue SE
Post #489280 19th Sep 2018 7:33am
mrtidy
Well I've bought myself a set of deployable steps now have to decide wether to bite the bullet and try to fit them myself or pay my local indy to do it mmm. 2009 Vogue SE Zermatt silver
Post #489344 19th Sep 2018 7:36pm
kooky_guy
It wouldn't hurt to find out what they would charge.
I had help from family with mine. I found the instructions quite hard to follow but they did make sense eventually! It's very satisfying. 2010 4.4 TDV8 Vogue SE
Post #489354 19th Sep 2018 9:45pm
Page 2 of 3 <123>
