![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2758 ![]() ![]() |
I've spotted a distinct difference between the pipes shown in diagrams/pictures and my April 12 build's pipe in that mine has a join between the flexible section and the rest of pipe that continues to the turbos. I can't currently loosen the bolt but once I have an appropriate tool, the end section of the pipe will be removed to allow the o-rings to be fitted whilst away from the back of the engine. |
Some measurements from mine's later version 2-piece pipe:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
where is that pipe from exactly Graeme?
Its at the top end of what was originally a single pipe. I suspect the 2-section pipe was developed so that it could be guaranteed that the fitting into the block could be under no stress. I rejoined mine after tightening the spigot in the block.
RiDDO Member Since: 13 Nov 2015 Location: Lincolnshire Posts: 33 ![]() ![]() ![]() |
My 2012 TDV8 is currently at Duckworth's in Market Rasen having a new oil cooler, alternator & n/s rear light cluster. I've been smelling hot oil for almost a year, last Sunday afternoon smoke started coming from under the bonnet. Note to self in future check for this stuff on Full Fat! --RiDDO |
Ian S Member Since: 01 Sep 2018 Location: Fufe Posts: 1 ![]() ![]() ![]() |
Hi all I’ve just found oil leak on my tdv8 I’m going to check it tomorrow |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
"First, remove the air box that houses the pollen filter, 2x 13mm headed nuts then pull the whole assembly off. "
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Picture with airbox removed. (2x 13mm nuts to remove. 30second job.)
Cheers. I was after the location of the nuts - or is it pretty obvious |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Thanks. Helps heaps. Will be having a gander over next few days under there when I collect my 2011...
Take a good look at this hose joint whilst you have the bonnet up.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
That fitting failed on my car,fortunatly under MP.Nino_Nino has posted the fix and yes it is easy!! 2012 TDV8 Vogue SE 4.4 |
