Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!!
Page 4 of 7 <1234567>
DrRob
nino_nino wrote:
SinbadRose,
JCW is correct, it is very unlikely that the cooler itself hase crac and is leaking. get some competent mekanic get this two gaskets from Duckworth Dan and you are set. if I remember correctly gaskets are 15-20 pounds.
Nino Thumbs Up
Are there 2 gaskets between the cooler and engine? Thanks Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #490357 29th Sep 2018 7:13pm
nino_nino
Yes, Rob. Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #490398 30th Sep 2018 8:30am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My car lost it's water.Crack in the oil cooler according to dealer foto.Waiting for the quote Big Cry Big Cry Big Cry Hopefully no engine damage,as I stopped soon after "low coolant" message.It was cool(15c) and engine was not to hot.Not a nice feeling.Car on 113k kms. 2012 TDV8 Vogue SE 4.4
Post #490586 1st Oct 2018 6:40pm
Frans@Yamorna
The offending part 2012 TDV8 Vogue SE 4.4
Post #490630 2nd Oct 2018 5:28am
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Just to confirm I had the gaskets and O ring changed on my L322 about 6/12 months ago and that was it - job done, no more leaks and no damage to the cooler itself - it was actually the gaskets on mine but I did the O ring too because that seemed like the right thing to do.
Have people started to see it on the L405’s yet? - I could change them on my new one (80,000m) as a precautionary measure if they have 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #490636 2nd Oct 2018 7:37am
GraemeS
Australia
I would leave changing gaskets until a leak is detected in case more suitable gaskets that withstand the heat from the EGR cooler become available unless other sealant will be used. Replacement gaskets are the same part number as the originals so will be the same material and therefore will also leak once they too go hard.
Post #490640 2nd Oct 2018 8:04am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
A WORD OF WARNING
Just read this post this morning - very interesting.
All our cars go to one main dealer - all their lives - and boy I am so glad they do.
LR dealership was tasked to service one of the FF and in the service the tech guy decided to replace the oil cooler ( car had done 140K ) - with no problems at all - it was a routine service.
Cut a long story short - the tech guy did just what you guys must not do - break the unit - still not sure what he did - but he did me a great favor -
Ended up with a BRAND NEW £25,200.00 complete engine with all the ancillaries: Water pump, Starter, Alternator, Fuel Injectors, Belts - everything new
So - ALWAYS GET YOUR FF SERVICED AT THE MAIN DEALER - If things go wrong they hold their hands up and put it right and in my case - A NEW CAR !
So Thank You Jaguar Landrover
My advice is don't try this at home - leave jobs like this to the experts - Jaguar Landrover Technicians.
I know some of you try to save costs and do jobs yours self - but even this one I would not even look at myself - Too much to go wrong and I have seen what can happen.
So be careful guys !
Post #490642 2nd Oct 2018 8:38am
GraemeS
Australia
So why did LR issue the TSB for the oil cooler gasket, make the gasket available as a spare part and add the procedure to the WSM? It seems to me that someone at the dealership stuffed-up causing the engine to be damaged so had to fix it. The task is a simple one but requires that the oil is not contaminated in the process.
Post #490646 2nd Oct 2018 9:47am
EmiratesA380
Hi GrahamS
All I know is that - some things are simple for Mortal Man to do and some things are just left for Gods to do !
and from what I know even I would not touch this - If a trained LR technician got this wrong and he did - that means Its a very serious piece of kit to F U - period !
Just want all you guys to know - Things can go very bad indeed - Better to know that not !
Post #490647 2nd Oct 2018 9:58am
GraemeS
Australia
Maybe an apprentice didn't appreciate the care that an open, post-filter oil-way requires. Even the task of replacing an inlet manifold where the camshafts are exposed doesn't require the same care because the oil is pre-filter with only the oil pump exposed to damage.
Post #490649 2nd Oct 2018 10:08am
EmiratesA380
There's Mortal Man ...... Then theirs Gods
enough said
Post #490651 2nd Oct 2018 10:26am
DrRob
Who did it and how much? Gathering quotes for me and the forum Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490655 2nd Oct 2018 11:18am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I would love to know what the guy did in order to lunch the engine.
Maybe he stuffed some paper in the oil galleries to stop debris getting in, and forgot to remove it ?
I appreciate this mechanic did something that cost an engine, but that is no different to doing an oil change: Forget to tighten the sump plug and it can be game over. Same for so many other simple jobs. That doesn't mean we should all stop doing it though, does it ?
A mate of mine who is a mechanic forgot to tighten the sump plug on a car when he was an apprentice which then needed a new engine. He got sacked on the spot.
Fair play to the dealer for replacing the full engine though, bit of a result for you Cool Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #490670 2nd Oct 2018 12:47pm
SinbadRose
one of the guys i work with told me about the indy he uses, dropped in, as soon as i mentioned what i had been told, he laughed, popped the bonnet, took a look and said 1.5 hours and gaskets, end of. Booked in on first available slot.
Won't be using or recommending the first guys i went to. He claims to be a level 11 tech from LR.
Post #490691 2nd Oct 2018 3:39pm
Frans@Yamorna
Just received update from JLR workshop!!!!Bad news,it is the EGR cooler that cracked,not the oil cooler and the repair cost is much higher and that component is not covered by my extended policy Big Cry Big Cry 2012 TDV8 Vogue SE 4.4
Post #490727 2nd Oct 2018 6:50pm
