|  | Home > Technical (L322) > 2007 TDV8 complete electrical failure |
| Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 62     |
 Hi all
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102     | I'm by no means an expert on this model or year, perhaps search here for ignition barrel failure........ Current: 2011 FFRR Vogue SE 4.4 TDV8
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797   | My money would be on the ignition barrel, I’ve changed one myself and know of others from 07 that have needed it. It isn’t ruinously expensive and isn’t too hard to change. | ||
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790     | +1 for the barrel. There is nothing that can't be fixed with a hammer😜😜
| Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 62     | Thanks guys really appreciate you taking time out to help. | ||
 So, the garage is still working it out, so i have asked for and will receive a refund for the car!
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577     | Your call on a refund but if it is the ignition switch it's a known fault and when fixed its sorted.  Another of similar age may well be the same 6 months down the line and then you will be picking up the tab.
| Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 62     | Thanks Grofus, all covered by warranty so should be ok. Appreciate the thought though, thank you
| Posting Rules
