Home > Technical (L322) > How long for suspension to rise back to normal?
Page 1 of 3 123>
Andy
My EAS seems sluggish. When driving off from access mode, the light flashes as it should. I timed it the other night and it took 1 min 44sec to go back to the normal setting whilst driving along. I've read somewhere it should be back to normal ride height within 50 yards, but I managed to drive the end of the street (nearly 1/2 mile) before it was back to normal. It takes 8 seconds to lower. It all seems to work fine apart from that - motorway setting, off road etc. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #4906 13th Apr 2009 12:14pm
Larry
England 2006 Range Rover SE Td6 Java Black
Shouldn't be that long. Yours does sound very sluggish. Do you get the message on the dash display saying its raising slowly? If I sit there and raise and lower the suspension a couple of times I get that message, presumably because I've used all the air in the reservoir and it's not had enough time to replenish.
Mine starts going up after 50 yds, and then takes a few seconds only to get to normal (I'll time it next time I'm out, but I don't think it's more than 6 -7 secs), It's certainly raised to full height after about 75-100 yds.
Post #4907 13th Apr 2009 1:08pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Owners manual says: ......until 180sec. XJC, RRV8, Series1 86 and 107% of real pleasure
Post #4913 13th Apr 2009 4:00pm
dan_uk_1984
There should be enough air in the reservoir tank to do at least 1 raise from access to standard, but in practice I have found it takes an age to get from standard to extended. I think part of this may be wait comands - the suspension should adjust under heavy braking/accellerating/cornering so sometimes I think this may be whi its not going anywhere.
I'd quite like to fit a second air tank to make faster moves, maybe with a secondary (much cheaper) air pump from a classic/P38 that just works off a pressure switch to supliment the original pump.
Dan
Post #4915 13th Apr 2009 5:30pm
It does sound like its sluggish and there may be a simple issue. Odd that the EAS is derived from the original system trialled on the Classic and then on the P38, so why it still has problems who knows..
Sorry to be pedantic but 'extended' mode is not the same as the Off Road height. Extended CANNOT be manually selected but is an extension above Off road height that occurs when the vehicle senses it has grounded. When this occurs the driver can then also select to go evern higer by using the 'up' selector on the EAS control knob.
Occasionally mine has gone into extended mode and it's quite astounding how high it goes, next time it happens I'm going to go for the ultra extended height and take a picture.
Here's a couple of places to find extra help:
http://rangerovers.net/repairdetails/airsu...aults.html
http://rangerovers.net/rrmkiiiremedies.html#suspension
http://rangerovers.net/repairdetails/airsu...index.html Discovery 4 HSE
Post #4922 14th Apr 2009 9:02am
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
I don't want to depress you but my '02 was doing that when I bought it, shortly after I had to fit a new compresser It now shoots up and down!
Ivan FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #4924 14th Apr 2009 9:32am
dan_uk_1984
Sorry, I was using layman’s terms, because when you say off road mode people get confused! When I was reading through the description and operation section in the workshop manual I actually found no mention of the “Extended Mode” that was implemented in the Classic and P38 System.
To say that the L322 EAS operation is in any way based on the Classic/P38 system is stretching it… The system was completely re engineered from the beginning (which is why although lessons were learnt from the earlier systems, a whole host of new problems were introduced). The EAS ECU on the L322 is far superior, with a greater range of Plausibility Scenarios and a better ability to work around system failures using substitute values and complex mathematics to work things out.
Anyway, back to Extended Mode – I think it was ditched because of the Crosslink Valves, you couldn’t have both systems.
If you can find info on Extended Mode then I would be very happy, I was shocked that the L322 doesn’t have it.
Dan
Post #4929 14th Apr 2009 10:49am
Vogue
I read in my handbook that the "super" extended mode could be activated by keeping your foot on the brake and moving the button again over to the high postion, but no matter how many times I have tried, I still can't seem to get the sequence right...
mines about 5 secs low to normal mode - suprised me how quick she is
Post #4931 14th Apr 2009 11:06am
I tried mucking about with the modes one day , and just kept the knob in the raise position for a good few seconds after and the " Extended Mode " kicked in and lifted it even higher ............ ====================================
Post #4932 14th Apr 2009 11:10am
dan_uk_1984
OMG - the excitement is too much! I'm guna go try this at lunch time!!
Post #4933 14th Apr 2009 11:12am
Vogue
yes thats what I tried to do, right lunch time I'm giving it a go too Cool
shall we be real enthusiasts and time them - best of 3 access to extended. Winner gets a new bic to shave their beard Laughing
Post #4937 14th Apr 2009 11:57am
dan_uk_1984
From Access, from Standard or Off Road?
What correction factors shall we use for Altitude and Temperature?
Dan
Post #4939 14th Apr 2009 12:11pm
Vogue
a real enthusiast would do a lap time from access to standard, to extended to super extended, average it all out over 3 and correct to 4 decimal places, post the results and also have a poll to see who's was the fasted...
and then post a link to it all on www.IamaLRenthusiast.com Shocked Laughing
Post #4940 14th Apr 2009 12:15pm
dan_uk_1984
I got all excited then and clicked the link - I might have to register that domain!
Post #4942 14th Apr 2009 12:17pm
As it's a sunny day, don't forget to take off your Corduroy jackets with leather elbow patches! Discovery 4 HSE
Post #4943 14th Apr 2009 12:45pm
Page 1 of 3 123>
