![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 546 ![]() ![]() ![]() |
Yes it can with the patch available from BAS. The price is on their website but from memory it's about £250. 2016 Skoda Octavia VRS Estate
https://bellautoservices.co.uk/store/rrs-3...-road-use/
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
My iid tool (Bluetooth) has stopped communicating with the car and also cannot be found when I try to update on the gap app on my computer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
delete all software and reinstall again.. |
Hi Stan
Just to update I emailed gap with the problem and they said it was defective, and a new unit is on its way to me from Canada |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I’ve got an L322 and would like to use the front sidelights only as DRLs, is this something that can be done? I can only find sipped or main beam in the menu but these turn the rears on too. |
unfortunately you cant on a 2007 year... |
Thanks, that’s the answer I expected |
there is a way round it though...you can connect the front sides to an ignition feed.. |
Thanks, I’ll give t a miss as I don’t want to go messing around with the wiring. Would have done t if it was just an option on the software though |
Lakeranger Member Since: 09 Oct 2015 Location: West Texas Posts: 4 ![]() ![]() ![]() |
I'm looking for a list and description of all available change options in the IID Tool, primarily for the ECU's. I don't want to make a change based solely on the name of the option, as some may not be what I think they are. I've searched other forums but haven't yet found these descriptions. I don't understand how all of us using this tool can know what these options are and the consequences of making the changes. Gap-Diagnostics has multiple warnings in the manual NOT to make any changes without understanding how the change will effect the vehicle. I don't want to "brick" my vehicle or any of the ECU's. |
there is a drop down menu on the GAP website that lists what can be adjusted, other than that you could search this forum for suggestions... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Just bought an IID BT off here for the glovebox. Will sort owner transfer once it arrives.
