Home > Technical (L405) > Low battery indicator
Have this since a week or two - changed the battery but the warning still comes back Sad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #492379 15th Oct 2018 10:14am
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
I had this message , on my car, replaced battery but had to drive it for awhile, several days, the car then seems to know all is well and the message went away.
Post #495188 11th Nov 2018 12:13am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Do the newer models need the battery coded on the car via diagnostic?
Post #495196 11th Nov 2018 8:36am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
This may be of relevance - (Or at least the comments in reply)
I presume BMS stands for battery management system.
Post #495208 11th Nov 2018 11:55am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
there are those around here far wiser than me but IIRC you can't just change the battery like in the old days. You have to tell the cars' BMS that it has a new battery and give it a few basic details about it.
Post #495253 11th Nov 2018 9:01pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi
I have replaced my battery in the boot footwell in my 2014 RR.
I bought the similar battery from Europarts and the only mistake i made was not informing the InControl guys as this brought up an alarm at their end and hence they phoned me.
I did not need to have the car recoded all went back to normal
3.0 Autobiography 14M5
Post #495266 11th Nov 2018 10:45pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I get it all the time on my 2013 if the car is not driven for more than a day. It appears to relate to me doing only short journeys most of the time now. If I do a longer journey (say 60 miles round trip) it is then OK for a few days but then even after say a 5 mile run, as I stop the car the 'Low battery, please start engine' message comes on (why would anyone then start their engine and sit there for an undefined time period or go for another drive when they had obviously just arrived at a destination and turned their engine off - dumb idea!). Even after a few days it has never not started for me after having the message. I had the battery checked by the main dealer a few weeks ago and they confirmed the battery was in good condition when they tested it and also said it was due to me only now doing short journeys (as was the excess diesel in my engine oil courtesy of the DPF, also due to short journeys - I have done 3000 miles in last 6 months) . I bought a CTEK MXS 3.8 battery conditioner/charger to hook it up to if I know I won't be using the car for 2 days or so, it seems to do the trick and is always there should the day come when the car doesn't want to start due to the low battery Smile Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #495521 14th Nov 2018 12:10am
RRVSE
For info guys, it turned out my battery issue was actually due to water ingress (windscreen on drivers side at A pillar) which over months slowly leaked in and gradually wet all my carpet and was shorting my battery. Once water issue fixed, battery has been fine and never used charger since. Steve
Post #522197 19th Jul 2019 5:06pm
