Home > Technical (L322) > Key won’t turn in ignition
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
After 10 weeks I am currently on breakdown #1 of what I am sure will be many. Came out of work yesterday and the key wouldn’t turn. Unlocks and locks fine on the button. Three clicks when turning putting the key in.
AA done a battery reset which sorted it, drove it home and turned it off. Turned it back on no problems.
Thought I’d charge it overnight as he mentioned the short journeys could be the problem. Took the charger off and tried the key, started no problem. Turned it off again and tried to turn it back on but the same problem has returned.
I’ve read a bit on here and other forums, sounds complicated but a common theme is that the steering column must talk to the barrel in order to release the steering lock and the barrel.
Got it in a garage now who are looking at it, an independent 4x4 who specialise in Land Rover. We’ll see what they say.
If anyone knows of a miracle cure I would be extremely grateful.
Post #492740 18th Oct 2018 10:48am
dingg1
common issue I'm afraid and can be really expensive if you want it to be BUT there are a few remedies
read this thread for a few of them
http://www.fullfatrr.com/forum/topic40178-15.html
then if you want the fix that has worked for me for about 3 years now with no more issues try this
http://www.blackbox-solutions.com/photos/L322lock.pdf
theres also this that may be tried
http://l322rangerover.blogspot.co.uk/2017/...eaded.html
if you drill the casting get plenty of wd40 into that hole to wash out any crap and then plenty of silicone to lube the solenoid
good luck
Post #492779 18th Oct 2018 2:03pm
CS
When my 2004 car's battery was very flat the key refused to turn. Maybe the effort of powering yours up and starting it was enough to get it back down to the level where this happens. Maybe get the battery tested and if necessary replaced. Only Range Rovers since 1988
Post #492780 18th Oct 2018 2:38pm
Full Fattie
I’m hoping it’s either something minor or the drilling of a hole will sort it. Should find out tomorrow then I’ll post the findings.
Post #492844 18th Oct 2018 8:10pm
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Had this happen to me about 12 months ago. The AA were convinced it was the battery, but on further inspection it turned out to be a dodgy ignition barrel. The technician did say that the he could still get the key to turn by gently pushing it in further, but we changed the barrel anyway. Wasn't too expensive as I seem to recall and no issues since. Life is what happens while you�re making other plans.
Post #492883 19th Oct 2018 8:24am
Full Fattie
I’m really hoping it could be this.
It’s putting codes up for the airbag, fault with the key and fault with the steering. I assume they’re all connected
Post #492892 19th Oct 2018 10:26am
Full Fattie
Had a slight update on the car Saturday. Car is starting fine today although nothing has been changed. They’re keeping it until the problem comes back so they can have another look.
Post #493079 21st Oct 2018 8:01am
Full Fattie
Garage have been on to say it’s now working fine. They’ve traced a fault to the airbag power supply and suspect that could be the issue. That’s fixed now but they’ve also warned me that if it is the column that needs replacing then it’s £4,500 for the part.
I do of course have the option of the DIY repair should t come to it as suggested by dingg1.
If this is a fairly common problem on 2002-2007 cars then does no one offer a recon of the faulty part?
Post #493223 22nd Oct 2018 11:10am
