Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died
Page 4 of 7 <1234567>
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Probably not a lot on the drivetrain, I assume you put it into neutral rather than standing on the brakes? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #492977 20th Oct 2018 9:25am
Amazing
Run away kill
The FV432 had a pedal(where clutch would be)in case of run away.
Experienced this briefly on a iveco van when it holed a piston. But a lot cheaper to fix...
Sorry to hear your news...time for am electric conversion... it is better to have and not need then need and not have
Post #492978 20th Oct 2018 9:36am
Richardince
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Did not put into Nuteral, was driving up 25% narrow Road and I was more worried about what was happening and trying to push the stop button to turn off. (Which I now know was not going to do anything) when finally stopped car was in park.
Post #492979 20th Oct 2018 9:37am
AJGalaxy2012
The main point was not stopped in drive with the engine flat out and the brakes on which could damage parts, park, neutral or moving along the transmission I would think will be ok. BMW i3 Electric Car
Post #492981 20th Oct 2018 9:40am
Baltic Blue
Have the dealers been able to offer any ideas as to why it went into meltdown ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #492982 20th Oct 2018 9:45am
Richardince
I have not seen the video diagonosis that has been sent to JLR but was told on phone the likely cause was a turbo breakup which then sucked oil out of engine to keep the engine spinning faster and faster till it destroyed itself and finally stopped.
Not happy about it especially when I had recently been looking at a new 124K Autobiography. I will be waiting to see how this pans out before ordering a new one.
Post #492983 20th Oct 2018 9:56am
AJGalaxy2012
What sort or age / mileage was your rangie? BMW i3 Electric Car
Post #492985 20th Oct 2018 10:44am
Richardince
Collected from the factory May 2014 62k miles
Post #492988 20th Oct 2018 10:53am
Baltic Blue
Please can you confirm if it has had the turbo drain mod, either as a factory fit before delivery , or if done as a modification by the dealer at a later date, .
Just to stop unproven speculation.
Post #492989 20th Oct 2018 11:12am
AJGalaxy2012
I would have thought you would have a very strong case against Land Rover, it must have been defective at time time of sale for this to have happened. No matter what the manufacturers say, the law takes on a very different view, I'm not sure of the exact details with cars but with electrical goods, many manufacturers give 12 months, some 24 months but the reality is 6 years! Ive just had a Samsung TV replace under warranty after 5 years. The supplier told me 2 years and that was the end of it, I involved trading standards, EU law states 6 years and the deed was done. BMW i3 Electric Car
Post #492990 20th Oct 2018 11:25am
Richardince
I have asked re turbo mod but have not got it stripped down as yet. Balance between finding out contributions from JLR or ploughing ahead on my own.
I will get an answer to this
Finding my Nissan GTR fun as don’t normally drive this time of year!
Post #493001 20th Oct 2018 1:57pm
GraemeS
Australia
LTB00524V6 for too many DPF regens lists VIN upper limit of 160137 as being caused by the single secondary turbo drain but perhaps the later drain was retro-fitted anyway. The isolation valve should have closed as soon as the throttle pedal was released or the engine was switched off so not a foregone conclusion as the cause even if fitted with the earlier style drain.
Post #493078 21st Oct 2018 6:46am
GGDR
Where do you get all the bulletins from Graeme?
. Cheers, Greg
Post #493113 21st Oct 2018 2:31pm
GGDR
Oh and what is the isolation valve you mention Graeme?.
. Cheers, Greg
Post #493114 21st Oct 2018 2:33pm
GraemeS
Australia
The later TSB showed-up when looking for V3 of the original L322 LTB00513. V3 lists the L405 VIN range for the smoke issue.
The secondary turbo inlet isolation valve, sometimes called a shut-off valve, is normally closed stopping air from getting into the secondary turbo. It is opened under ecm control via a solenoid only when the ecm determines that the secondary turbo is required. Driver demand (throttle pedal input) is the primary criteria, not engine revs.
Post #493160 21st Oct 2018 8:56pm
