Home > Technical (L322) > First time Restricted Power Mode - Caravan Attached
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
From memory, Turbos will only spool up with engine pressure, ie under load. Simply reving an engine won’t necessarily generate the right pressures for turbos to spoil up correctly.
Noticed another thread on. L405 4.4V8 TDV8.....bad battery also threw up the same intermittent restricted power mode.
So, plan of action and plenty to go at with the dealer
Battery. - 12.15v so easy start point. - I always remember that 90% of failures are electrical, battery, sensors etc
Top plenum and rubbers - smoke test
Secondary valve
EGR
Check fault codes
Thanks guys. Really appreciate your thoughts and comments
Best regards
Mark
Post #493163 21st Oct 2018 9:07pm
GraemeS
Australia
A sticky inlet isolation valve will trigger restricted performance. An improved valve was fitted during the MY11-12 production run but my money is on the battery.
Post #493168 21st Oct 2018 9:42pm
nambFFRR
My car a late 2011 model so it might have the latest valve fitted.
It’s only done 48k miles and the engine bay is as clean as a whistle so far!
Post #493176 21st Oct 2018 10:12pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Namb you’re right at constant revs not under load the turbos won’t boost but if you hit full throttle from idle you will get a quick blip of boost as the engine revs up BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #493195 22nd Oct 2018 6:19am
GraemeS
Australia
The top of the valve is visible looking straight down behind the radiator just left of centre. Early versions have a nut clamping the lever to the shaft whereas the later version does not have a nut.
Post #493197 22nd Oct 2018 7:08am
nino_nino
old style valve.
Nino, 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #493203 22nd Oct 2018 8:28am
nambFFRR
So.....
Could this be the leak? It seems so insignificant given the cars only done 48k miles. This is more like a weep than a split in the plenum. There isn’t anything on the 4 rubbers. What do you folks think?
Post #493213 22nd Oct 2018 9:45am
nambFFRR
I tried it out on the road and sods law it won’t replicate the restricted power mode. I ran it through the rev range and no symptom displayed at 2500rpm so maybe discount the change over valve?
Post #493217 22nd Oct 2018 10:20am
Baltic Blue
Mine is a May2011 and had the old style valve with the nut, but if that is your problem you will know by reading the Fault codes, because it gives out an obvious fault code when sticking.
Post #493218 22nd Oct 2018 10:24am
nambFFRR
That’s what I’m hoping for. If a code is there that points to something specific there’s a chance it will be an easy fix.
Post #493219 22nd Oct 2018 10:34am
nambFFRR
Just checked....mine was registered 28/07/11 so might have the old valve....I’ll have to have a look....
Post #493220 22nd Oct 2018 10:45am
Baltic Blue
The small split in the seam of the plenum is very similar to what other members have reported as causing the problem giving restricted performance problems, particularly under load.
Post #493226 22nd Oct 2018 11:48am
nambFFRR
I’ll point the technician in that direction if that’s the case. I’d have expected a larger breach/split with more evidence (oil/soot on the engine and engine cover) than what I can currently see. Does this problem throw up an error code which pinpoints the split or drop in pressure or is it more generic? The only sensor I can see is the MAP sensor on the front section....are there any others for pressure in the system?
Post #493263 22nd Oct 2018 3:41pm
nambFFRR
Think the garage have pinpointed 2 faults.....minor split on the top plenum and weak battery. Both as suspected. Both now replaced. I’ll report back with any further info later this evening once I pick the car up and have had a chance to chat about the fixes they’ve done. I’ll try and find out what codes these faults threw up for future reference.
Post #493466 24th Oct 2018 1:56pm
nambFFRR
So. As mentioned earlier, Top plenum changed with the new ‘chunky’ rubber connectors compared with originals and battery replaced with a top quality new one. All seems to good once again....let’s see over the coming weeks!!
I’d like to thank everyone on the forum who passed comments through to me. It’s really appreciated.
Best regards
Mark
Oh...other stuff done recently, underside steam cleaned an waxoyled especially in the main body chassis points. Leaves me to do the doors and the bodywork panels sometime next year now. Tow bar and exhaust repainted satin black which has tidied up the rear end nicely.
Post #493482 24th Oct 2018 5:41pm
