![]() | Home > In Car Electronics (L322) > Low Aux In Volume Issue. Looking for a solution. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Have you tried turning the volume up on your phone rather than the car? Worked for me. |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 ![]() ![]() ![]() |
i have the same issue, i am sure i have seen somewhere an amp for the aux cable, very small maybe 25mmx25mm, i am not sure where i have seen it though, i think on here but cant remember, it did have a photo that's where i have guessed the size from, it may be a solution to the problem, maybe someone else with much more knowledge and a better memory can help!
Hi,
Just a thought, which type of phone are you using ? If iPhone there are a couple of app settings you can check / alter to make the sound output level increase which in turn would increase the aux sound level. |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Thanks for the recent responses.
mine is exactly the same i have everything turned up full but have to turn up the volume on the head unit, and yes you're right
I plug in direct - no extension cables. Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
