![]() | Home > Maintenance & Mods (L322) > Airbag (suspension) replacement |
| nosmo Member Since: 05 Nov 2017 Location: Derbyshire Posts: 41
2003 Vogue
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
I assume you have seen Storey Wilson's video
Yes 1 of many I have watched but in this 1 he doesnt install any orings |
At @ 8:30 he inspects the airbag and sees the O rings inside. They may have changed the design since his video was made ? .
Yes I see that now. I will try installing the orings into the airbag and try it that way. |
Its been suggested to use an air compressor to inflate the bag to force it into place |
This video also
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
I don’t know why you would want to keep the shock in a 2003 model. It would be not be functional. ______________________________
How will it inflate if the sealing rings are not in place? Surely it would leak? |
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
one of my struts was reently replaced so i took the old one apart to see inside |
The image was only to show those bottom orings as this is what I am having the problem with. I know they are seals but the airbag will not go over them. Its like they are slightly too large. |
