![]() | Home > Technical (L322) > advice alternator |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Iid tool
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 ![]() ![]() ![]() |
ok thanks i will have a look, see if i can find it |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3860 ![]() ![]() ![]() |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 936 ![]() ![]() |
I've just replaced the alternator on my 4.4 TDV8 so if you do decide to change it yourself, happy to provide advice if needed - I'd assess as a 6/10 difficulty as a DIY, although more fiddly than difficult. |
Thanks all i think it will be the alternator but just checking other peoples experiences, its covered under warranty (rac) |
You'll save yourself the skinned knuckles I'm currently sporting! |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Just my 2p worth, but doesn't the intelligent charging system not start charging until the engine has been running for 2 minutes?
Mun Member Since: 17 Jun 2018 Location: Reading Posts: 16 ![]() ![]() ![]() |
Hi, I have just had the same problem, it turned out to be the alternator. There was also a slight burning smell (which apparently accompanies a alternator meltdown). |
Hi yes i thought that about the intelligent charging system, so i checked at 2 min intervals for about 20 mins still no change,
