Home > Technical (L322) > FBH - Only running for a few minutes. |
Been puzzled by this one for a few weeks. But then with my recent flat battery it dawned on me that the FBH ECU turns the FBH off if the voltage drops to 11.4v.
9th Feb 2011 7:56pm |
herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51 |
Did you check that your alternator is charging correctly when running? I think its supposed to be around 14.2V. |
9th Feb 2011 8:01pm |
Yup, alt' charges fine. The battery voltage drops off quickly though which is generally down to damaged plates.
9th Feb 2011 8:10pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Odd - My bottle of De-icer and scarf have had no such problems...... have you left the air con on
10th Feb 2011 4:43am |
All parts are available to buy direct from LR, or you can buy the kit brand new for around £500. D |
10th Feb 2011 9:55am |
