Home > Technical (L322) > FBH - Only running for a few minutes.
dan_uk_1984
Been puzzled by this one for a few weeks. But then with my recent flat battery it dawned on me that the FBH ECU turns the FBH off if the voltage drops to 11.4v.
I hooked up the multimeter and started the FBH, sure enough after about 5-10 minutes the voltage dropped to 11.4V and the FBH shut down.
I need a new battery Sad
Post #49499 9th Feb 2011 7:56pm
herman maire
Canada
Did you check that your alternator is charging correctly when running? I think its supposed to be around 14.2V.
Post #49502 9th Feb 2011 8:01pm
dan_uk_1984
Yup, alt' charges fine. The battery voltage drops off quickly though which is generally down to damaged plates.
It turns out that my battery is only 7 months old - however Guava of Guildford fitted an 80Ah battery from a Freelander rather than the proper 110Ah battery.
No wonder the poor thing has been struggling to start in the cold mornings.
I will be expecting them to replace it with the correct battery!
Post #49503 9th Feb 2011 8:10pm
herman maire
Canada
Well, at least its a easy fix and less expensive VS repairing/changing the alternator Very Happy
I had a new battery installed this january, even with a new battery, when it -30c it still has a tough time cranking. I would still like to get my hands on a similar FBH like yours.
Post #49556 10th Feb 2011 1:50am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Odd - My bottle of De-icer and scarf have had no such problems...... have you left the air con on Question Whistle
Wink 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #49557 10th Feb 2011 4:43am
dan_uk_1984
All parts are available to buy direct from LR, or you can buy the kit brand new for around £500.
D
Post #49562 10th Feb 2011 9:55am
