![]() | Home > Technical (L322) > TD6 not cranking, lights out |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
I would check your battery connections are clean and tight as I had a problem that appeared to be a flat battery but was a poor connection although tight I had to clean inside the battery connection with coarse emery cloth.
| Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111
my starter motor was quietly failing and i had lots of issues like this that seemed to be low battery.
It sounds similar to the TD6 I worked on that had a faulty ignition switch but the thread below goes through a few things to check, methodical testing with a multimeter is the key in my opinion?
| clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183
Shame on me, i think the earth connection was a bit loose 😱 But i thank everyone fot the answers!
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
..it happens, let us hope that was the problem |
| All times are GMT |
