Home > Technical (L322) > Adaptive Dynamics Towbar/Towing Issues?
therso
Looking forward to picking up my 2011 Autobiography this coming Thursday so today I visited my LR Indy to seek his advice on a few issues. I asked for a quote to fit a fixed towbar and electrics and he asked if it had Adaptive Dynamics, or I think that was what he said. Anyway I had no problems with my D3 and D4 but they had all the electrics fitted etc. so should I expect the RR to present something more complicated? I only tow a small touring van. Any advice will be very welcome.
Post #495392 12th Nov 2018 6:26pm
kooky_guy
Well it will have active dynamics, but what that has to do with a towbar, I don't know. 2010 4.4 TDV8 Vogue SE
Post #495446 13th Nov 2018 8:56am
rjff
HI, and I hope this helps.
We have a 2011MY Vogue and she came with active dynamics and a tow preparation. Some info came from the selling dealer and some from the build sheet which I obtained from vindecoderz web site.
Link here:
https://www.vindecoderz.com
Search under your VIN and it should tell you if tow preparation was fitted. The socket for the tow bar electrics will then be found in the spare wheel well, nearside rear bulkhead. It's grey IIRC. This should allow plug and play to the tow bar and trailer.
My understanding is that the active dynamics will continue to operate, but the suspension may prevented from raising to off road height if selected. I assume that prevents grounding of the rear of the trailer in certain conditions. (members, please correct if required)
I went the route of a Westphalia (original fitment if ordered with the car) detachable with 13 pin electrics and that was simply install and drive away with the tin tent attached. Can be done DIY if you wish, but the bumper comes off for the work. I would suggest you go 13 pin as the socket will take an adapter for the older twin T&S plugs.
Some good info on the P F Jones website, drawings, fitting details and electrics, good for research, but DO shop around and make your own decision on supplier/installer.
You will love the Fullfat, (statement not an order). Perhaps you would like to update your profile with the car details. Cheers
Richard
Gap IIDBT
Post #495479 13th Nov 2018 7:27pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
The main thing to bear in mind is that the towbar and electrics will work fine if you just plug and play...
But to get the best from it, including the suspension working with the engine to reduce the chances of the trailer wagging as you go along, you need to have the car coded to know it's got a towbar.
Post #495482 13th Nov 2018 7:58pm
GraemeS
Australia
The car will know if a trailer is attached if the trailer's globes are incandescent or if load resistors are fitted to the trailer's blinker circuits. The CCF parameter is purely a build notation as to whether or not a trailer socket loom was fitted.
Manual height changes are still available but some auto height changes such as auto selecting off-road height when in rock crawl are inhibited. Auto lowering from off-road height at speed still occurs though.
Post #495488 13th Nov 2018 8:39pm
mjdronfield
But none of that is specific to later cars with Adaptive Dynamics, is it?
So I’m still not sure how the adaptive dampers affect towing. Intrigued now....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #495498 13th Nov 2018 9:40pm
GraemeS
Australia
Perhaps someone suggested having adaptive dynamics might be an advantage if towing, with which I would agree.
Post #495514 13th Nov 2018 11:25pm
mjdronfield
This prob explains it
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #495515 13th Nov 2018 11:33pm
GraemeS
Australia
I doubt that active dampers need to be told that a trailer is attached as they react to movement of the suspension and the vehicle as a whole, let alone that trailer weight can vary from a few hundred kg to 3.5T for the RR.
Post #495524 14th Nov 2018 1:12am
mjdronfield
No idea why the tow bar people would ask if it’s got adaptive dynamics then. Interesting......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #495527 14th Nov 2018 8:26am
therso
Thank you for all your replies and comments especially rjff for the link to the build sheet. It shows '7 Pin X Bar Detach Tow Ball (028CC). I've clearly missed something. I take this to mean there should be a detachable towball plus all the towbar fittings etc.? Confused
Post #495552 14th Nov 2018 1:14pm
mjdronfield
Usually under the boot floor in a tray on the right hand side. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #495554 14th Nov 2018 1:40pm
rjff
Therso
I'm not quite sure what you are looking at in your ref to the above, can you let me know with a link please? Cheers
Richard
Gap IIDBT
Post #495581 14th Nov 2018 7:18pm
therso
Following your link to vindercoderz.com I opened the build sheet for my vehicle and it clearly states on the second line: 'Towing Equipment - 7 Pin X Bar Detach Tow Ball (02BCC)'. Spoke with the dealer who insisted that there is NO towing equipment on the vehicle as was proved when I was viewing it. As he is the UK's largest L322 used RR (The Vogue Centre) I think I'll take his word. He explained that the original owners may have changed their mind and it was a not uncommon issue.
Post #495587 14th Nov 2018 9:03pm
rjff
Therso
Apologies, did not make the connection to the build sheet (my bad). My build sheet shows (Towing Equipment - Towing Prep ROW [028BR])
From your statement that there is no towing equipment on the car, can I take it that there is no grey socket on the rear (inside) bulkhead, nearside of the spare wheel well?
This is as fitted on mine. The socket is the left hand half, with its loom covered with the same material as the remainder of the main loom. The cable to the trailer socket goes to the right.
If you have the left hand half (socket) fine, it’s plug and play. If you don’t, that’s another story and I would have to research how to go about installing one. It may be that others here have done it and can assist.
Let us know how you get on, please. Cheers
Richard
Gap IIDBT
Post #495623 15th Nov 2018 11:11am
