![]() | Home > Technical (L322) > 4.4 TDV8 Won’t start |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
"Battery was recently changed"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
if the battery is ok then it will be the starter motor which luckly for me was replaced under warranty.... |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Will do Weegie!👍 |
Mines also still under warranty so it’ll be back in the dealers tomorrow! |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Sorry to hear about the troubles, but at least mine waited a little longer before throwing its toys out of the pram.
You have all the same thoughts I’ve been having.....it’s a new battery so I expected 12.7v but can only see 12.1v. Something is amiss. I’ll see what the RAC guy says first.....
Fun aren't they |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I was about to say, 12.1 volts is basically flat. It will probably drop to around 11.5 volts as soon as you hit the start button. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1421 ![]() ![]() ![]() |
On my 2012 WM the 'system powered up, battery OK but click when starter pressed' was cured by fitting new starter motor. Apparently it's a common failure. Only Range Rovers since 1988 |
Thanks for the info
12.1v is around the 50% fully charged level but I agree, it should be 12.7v as it’s a new battery
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Mine used to rest at 11.4V and never had a problem starting the car. It wouldn't run the FBH though... 2010 4.4 TDV8 Vogue SE |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
I had the same problem and it was the starter motor which went at 40k on the clock. I replaced it myself and took the old one apart to find that the solenoid contacts had gone black which prevented the full battery voltage getting to the motor. When cold it meant that there wasn't enough oomph to turn the engine over. 2011 4.4 TDV8 Vogue SE
Managed to get home albeit very late (or early!!) at 3am this morning
