Home > Technical (L322) > 4.4 TDV8 Won’t start
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Hi
Well this is becoming tedious
3months into my relationship with the RR, today it decides it won’t start
All lights come on
12.1v at battery
Slight click can be heard when starter button pressed
Nothing other than low battery warning
So sat waiting for RAC so we can head home to North Yorkshire - we’re currently sat in Lewisham in London at our son’s place
Battery was recently changed when the top plenum was changed
Any thoughts? Alternator maybe? Any clever electronics to check?
Any help would be greatly appreciated
Regards
Mark
Post #495915 18th Nov 2018 6:40pm
Weegie
"Battery was recently changed"
Even if you have alresdy done so recheck the terminal connections. John
GAP iiD BT-Sold
Post #495917 18th Nov 2018 6:48pm
if the battery is ok then it will be the starter motor which luckly for me was replaced under warranty....
Post #495918 18th Nov 2018 6:49pm
nambFFRR
Will do Weegie!👍
Post #495919 18th Nov 2018 6:49pm
nambFFRR
Mines also still under warranty so it’ll be back in the dealers tomorrow!
Post #495920 18th Nov 2018 6:55pm
rjff
Sorry to hear about the troubles, but at least mine waited a little longer before throwing its toys out of the pram.
Might be obvious, but check the battery terminals and the voltage seems on the low side, should be up above 12.6. If the RAC man gets it running, check the voltage again after a few minutes and it should show about 14.5 or more to indicate charging. If it doesn't, then perhaps the alternator is on the way out or has failed. Mine started and got me about 15 miles then died at home. At home it had below 12.5 volts at tickover and then dropped after a few minutes to the point that the engine stuttered and stopped. If that's the case with yours then it may require recovery to home or your repairing garage. The battery will not get you the distance home.
If it starts and runs with a charging voltage, don't stop it until you get home Confused
If the starter has failed, it may be a recovery. Cheers
Richard
Gap IIDBT
Post #495922 18th Nov 2018 7:01pm
nambFFRR
You have all the same thoughts I’ve been having.....it’s a new battery so I expected 12.7v but can only see 12.1v. Something is amiss. I’ll see what the RAC guy says first.....
I was warned about the green oval.......
Post #495923 18th Nov 2018 7:06pm
rjff
Fun aren't they Razz
Love em or loathe them, you can't live without them. Now where have we heard that before.
Good luck or a small bill and let us know the outcome. Cheers
Richard
Gap IIDBT
Post #495924 18th Nov 2018 7:11pm
Paul thornton
I was about to say, 12.1 volts is basically flat. It will probably drop to around 11.5 volts as soon as you hit the start button.
Post #495933 18th Nov 2018 8:14pm
CS
On my 2012 WM the 'system powered up, battery OK but click when starter pressed' was cured by fitting new starter motor. Apparently it's a common failure. Only Range Rovers since 1988
Post #495935 18th Nov 2018 8:18pm
nambFFRR
Thanks for the info
RAC due in an hour.....hopefully to get us up and running
Post #495937 18th Nov 2018 8:28pm
nambFFRR
12.1v is around the 50% fully charged level but I agree, it should be 12.7v as it’s a new battery
Post #495941 18th Nov 2018 8:57pm
kooky_guy
Mine used to rest at 11.4V and never had a problem starting the car. It wouldn't run the FBH though... 2010 4.4 TDV8 Vogue SE
Post #495963 19th Nov 2018 8:50am
TomCobbly
I had the same problem and it was the starter motor which went at 40k on the clock. I replaced it myself and took the old one apart to find that the solenoid contacts had gone black which prevented the full battery voltage getting to the motor. When cold it meant that there wasn't enough oomph to turn the engine over. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #495965 19th Nov 2018 9:27am
nambFFRR
Managed to get home albeit very late (or early!!) at 3am this morning
RAC diagnosed a faulty diode in the alternator and a sticking starter motor. Battery and shutdown voltage draw checked and all fine on that front. Battery fine.
So...back to the dealer to get the repairs under way.
Thanks to everyone who came up with some really good suggestions. Much appreciated as always
Best regards
Mark
Post #495974 19th Nov 2018 10:28am
