![]() | Home > Technical (L322) > Bonnet release cable snapped |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
IIRC it is remove the passenger side inner wheelarch then employ a small monkey/marsupial to reach in and release the locks .
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
It's probably broke at the join that sits near the wing line of the bonnet. I'd order both cables. V8 or else ... |
Danbhardy Member Since: 10 Nov 2018 Location: Chorley Posts: 44 ![]() ![]() ![]() |
Oh so there’s 2 cables?
And also what part numbers they are?
Won't help you open the bonnet.
I’ll get both if I can, but don’t know what I’m getting! Lol |
Give Dan at Duckworths your VIN and he will get it right for you |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Mine snapped at the pull handle. I managed to get mole grips on the end of the cable and pull it.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
When mine snapped I removed the drivers side wheel, pulled the plastic inner guard cover off, reached up to the drivers side front corner between the air ducting and grabbed the cable , pulled and it opened |
Ok, removed the passenger side inner wheel arch, but no access to the bonnet release?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
the cable is not on the passenger side, its on the drivers side.. |
Access from passenger side inner wheelarch to access release catches / cable on slam panel
Well we found it has snapped at the handle, but can’t see the remains in the hole to pull |
Worth a try putting some hefty mole grips (or similar gripping/crushing tool) further up the cable to see if you can squash the outer cable and grab the inner in the process, then pull.
