Home > Technical (L322) > Bonnet release cable snapped
Danbhardy
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Well I went to change my sidelight bulb and me bonnet wouldn’t open Sad
Think the cable is snapped. It’s not at the handle end so it’s gone somewhere in the middle.
Now I’m away from home at work all week so can’t look at it, but need to order the part ready for the weekend Sad
Also how to open the bonnet etc......
Any help is gratefully recieved!
Post #496090 20th Nov 2018 6:20pm
IIRC it is remove the passenger side inner wheelarch then employ a small monkey/marsupial to reach in and release the locks .
Post #496093 20th Nov 2018 7:00pm
fisha
It's probably broke at the join that sits near the wing line of the bonnet. I'd order both cables. V8 or else ...
Post #496101 20th Nov 2018 7:29pm
Danbhardy
Oh so there’s 2 cables?
Does anyone have a picture at all of how they are both routed?
Post #496108 20th Nov 2018 8:30pm
Danbhardy
And also what part numbers they are?
As said I’m away all week so no access to the vehicle to see Sad
Post #496109 20th Nov 2018 8:37pm
Won't help you open the bonnet.
Comes through the bulkhead, runs along the side of the RH wing, then turns to the centre of the bonnet.
The two cables are joined with a connector @ half way along the wing
Best to get the bonnet open to see which one has broken, unless you choose to replace both. .
Post #496110 20th Nov 2018 8:38pm
Danbhardy
I’ll get both if I can, but don’t know what I’m getting! Lol
Post #496127 20th Nov 2018 10:09pm
Give Dan at Duckworths your VIN and he will get it right for you Thumbs Up .
Post #496137 20th Nov 2018 11:23pm
Andy
Mine snapped at the pull handle. I managed to get mole grips on the end of the cable and pull it.
It’s fairly easy to replace. It’s two cables joined together near the strut tower on the offside wing. All I had to do was replace the section from the wing to the pull handle.
Post #496236 21st Nov 2018 9:58pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
When mine snapped I removed the drivers side wheel, pulled the plastic inner guard cover off, reached up to the drivers side front corner between the air ducting and grabbed the cable , pulled and it opened
Post #496255 22nd Nov 2018 12:47am
Danbhardy
Ok, removed the passenger side inner wheel arch, but no access to the bonnet release?
Can someone enlighten me please!
Need to have it sorted by tonight Sad
Post #496486 24th Nov 2018 3:46pm
the cable is not on the passenger side, its on the drivers side..
Post #496487 24th Nov 2018 4:07pm
Access from passenger side inner wheelarch to access release catches / cable on slam panel
Access from drivers side inner wheelarch to access cable on slam panel or side of wing, if you can reach / feel for it .
Post #496495 24th Nov 2018 5:08pm
Danbhardy
Well we found it has snapped at the handle, but can’t see the remains in the hole to pull Sad
Still not got the bonnet open!!
Post #496498 24th Nov 2018 5:33pm
Worth a try putting some hefty mole grips (or similar gripping/crushing tool) further up the cable to see if you can squash the outer cable and grab the inner in the process, then pull.
Or cut back the outer cable with hacksaw ? .
Post #496501 24th Nov 2018 5:48pm
