Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles
Page 2 of 12 <123 ... 101112>
ilard
Something I came across... Driver & Vehicle Standards Agency email spam says:
New MOT standards improving our air quality
Following changes to the MOT test on 20 May 2018, more than 744,592 cars have failed the emissions test.
The cars have either been taken off the road or fixed, helping to improve air quality.
This compares to 350,472 cars failing the emissions test during the same period in 2017.
https://www.gov.uk/government/news/new-mot...ir-quality
Post #496136 20th Nov 2018 11:02pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Are you all aware what the E24 emmision limit marker is ?
On your L322 chassis plate or slam panel (or anywhere on other makes of cars) is a small square with a number in it
My TD6 is 2.03
This is LOWER than the MOT stated limit but it is the limit my vehicle exhaust gas has to be tested to as it is a manufacturers stated limit
Many vehicles have manufacturer limits way lower than MOT limits - it is no surprise that vehicles are failing their emmission test
An MOT carried out AFTER May 2018 will be subject to the new limits 2009 - L322 5.0 S/C Autobiography
Post #496139 21st Nov 2018 12:15am
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Yes, people are aware of this. That's why I said 'my' limit, not 'the' limit. There's no evidence at all that people are failing on EGRs, the article itself even just mentions increases being down to smoking and DPF's.
Out of interest I just rechecked my last emission test, and I was actually only just over 40% of my limit, so again, unless they can see through plastic, or your car has a serious issue, it seems incredibly unlikely
Post #496140 21st Nov 2018 12:35am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I find it surprising that not only can eBay turn a profit out of blatantly disabling emissions control measures, but that this site should readily include information and recommendations on how to do it.
The often quoted “defence” that a people are unlikely to be caught by the MoT seems no more valid for this than committing any other offence.
(Road Vehicles (Construction and Use) Regulations, 61a).
http://www.copfs.gov.uk/foi/responses-we-h...01-r103539
Post #496146 21st Nov 2018 7:01am
19sjw
England 2007 Range Rover Vogue TDV8 Tonga Green
Surely if blanking the EGRs makes the vehicle emissions no worse,probably run better,what is the problem with that? If it passes the test,whether or not the delete can be seen,it is totally irrelevant.
Post #496158 21st Nov 2018 10:14am
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
I think the site recognises common faults on the RR and allows fixes and remedies to be posted and not to flaunt the law
A lot of owners have older vehicles thar need a lot of maintaining so any thing that can reduce this is welcome by me .
On a personal note if my egrs fail and destroy the turbos then that car is finished because it's cheaper to buy a different vehicle .
Since blanking off the egrs I now have a FF that does not blow out a black smoke clould when accelerating hard so the engine is running cleaner , mpg is up by about 2.5 mpg somewhere about a 10% increase so the car runs better and cleaner and hopefully costs less to maintain, all positives and if it's illegal the process is easily reversible
Would be nice to see people being positive about this site which helps 1000's of owners maintain there vehicles to a high standard on a low budget
Post #496162 21st Nov 2018 11:23am
gj88
100% agree. I'm not that bothered either way if people want to do it or not, was more frustrated by the need to argue the morality of it on a useful how-to thread.
Ironically you've managed to solve a definite MOT fail by causing an unlikely one, seems sensible to me! Thumbs Up
Post #496163 21st Nov 2018 11:47am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Spot on Henda that's why its not worth the effort at times trying to help, there's always a google mechanic/lawyer on hand and probably who use the MD to look after the car and have money to burn or don't care. It works and helps so im happy along with hundreds more and safe to say it wont scrap the turbo or engine potentially Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #496174 21st Nov 2018 1:04pm
Henda
Hahaha scottyav spot on
Rolling with laughter
Long live FFRR Thumbs Up
Post #496183 21st Nov 2018 2:05pm
RS2000CUSTOM
I work for myself as a mechanic and do all my own repairs and I am a current MOT Tester (since 1989) - if owners are carrying out what is now an illegal modification or repair that "if found" will cause their vehicle to have a Major FAIL item applied to their vehicle then that is a decision they can make - I am simply pointing out that what PASSED an MOT last year will potentially FAIL from May 2018 ! 2009 - L322 5.0 S/C Autobiography
Post #496196 21st Nov 2018 3:31pm
nearlee
Wales
My 07 plate has just flown through it's mot 2 weeks ago. Remember:- amateurs built the ark
Proffesionals built the titanic
Post #496233 21st Nov 2018 9:40pm
Henda
Here's an update
So with over 300 miles covered I went out this morning and gave the FF a right blasting red lining the engine and here's my findings
No eml
No smoke on start up
Steady tickover ( no hunting )
Engine quieter and smoother
No hesitation when pulling off
No black smoke
Better fuel economy around 2.5 mpg better
I then plugged in the idd tool
No faults on egrs
No faults on injectors
Both of which I had previously
Live readings on egr valves - working but steady at 4% if that makes sense
Also the occasional restricted performance after hard acceleration is now gone
So for me at the moment this seems to have cured a few faults
So it's a Thumbs Up
Post #496485 24th Nov 2018 2:59pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Top geezer, thanks for the writeup, think I will be giving that a go Thumbs Up
Post #496786 27th Nov 2018 2:54pm
Scottyav
Unnecessary quote removed
Told you it would be good no issues to many doom and gloomers looking on google and gov.uk Laughing Laughing _____________________________________________________
Post #496792 27th Nov 2018 4:04pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hay don't you diesel lot fall out Rolling with laughter Rolling with laughter
Post #496796 27th Nov 2018 4:58pm
