Home > Technical (L322) > Air suspension front not going down
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Hi guys, does anyone have a air suspension diagram as i need to find the valve for letting the front suspension down.
changed front air springs and now the front wont go down quickly (takes a couple of mins) anyways if anyone can point me in the right direction that would be great. If i could would you!!!!
Post #497239 1st Dec 2018 6:44pm
Way back when, there used to be an issue with the exhaust's on the compressors gumming up with a talc type of substance... Unscrew the exhaust silencer from the compressor and see if that resolves the issue? Even try blowing through the exhaust when its removed Thumbs Up
Post #497240 1st Dec 2018 6:55pm
Hi Cam-Tech-Craig thanks for the reply, the exhaust you mention is it the one inside the pump pack or the one on the back of the spare wheel well? If i could would you!!!!
Post #497241 1st Dec 2018 7:06pm
Have a look here Thumbs Up
http://www.fullfatrr.com/forum/topic23038.html
Post #497244 1st Dec 2018 7:47pm
Thanks for that cam Tec, we have found that the right rear height sensor is faulty. Do you know what is different with the xenon headlight fitment If i could would you!!!!
Post #497350 2nd Dec 2018 7:20pm
The fitment of xenon lights would require a self levelling system for acceleration and braking, to keep the lights level and non blinding to oncoming traffic... Does that answer your question?
Post #497383 3rd Dec 2018 1:03am
Just check you get the correct replacement sensor, some had a six pin connector others had a three pin.
Fortunately the rear sensors are a lot cheaper than the fronts! .
Post #497393 3rd Dec 2018 10:05am
yes it looks like the 6 pin type are for the cars with xenon headlights as it is only the right rear sensor that has the 6 pin
thanks for all the help guys If i could would you!!!!
Post #497410 3rd Dec 2018 12:47pm
