![]() | Home > Technical (L322) > Air suspension front not going down |
Way back when, there used to be an issue with the exhaust's on the compressors gumming up with a talc type of substance... Unscrew the exhaust silencer from the compressor and see if that resolves the issue? Even try blowing through the exhaust when its removed |
| ARH Vehicle Logistics Member Since: 28 Jan 2012 Location: Shropshire Posts: 61
Hi Cam-Tech-Craig thanks for the reply, the exhaust you mention is it the one inside the pump pack or the one on the back of the spare wheel well? If i could would you!!!! |
Have a look here |
Thanks for that cam Tec, we have found that the right rear height sensor is faulty. Do you know what is different with the xenon headlight fitment If i could would you!!!! |
The fitment of xenon lights would require a self levelling system for acceleration and braking, to keep the lights level and non blinding to oncoming traffic... Does that answer your question? |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Just check you get the correct replacement sensor, some had a six pin connector others had a three pin.
yes it looks like the 6 pin type are for the cars with xenon headlights as it is only the right rear sensor that has the 6 pin
| All times are GMT |
