![]() | Home > Maintenance & Mods (L322) > Possible to deactivate/disable LED halo angel eyes? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
do you mean the fairy lights?
| Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121
More specifically, I'm referring to the pair of round halos that go around the circumference of the front headlights, as per the photo below:
do you mean these,
Correct, those are the lights in question.
you could cut a wire to permanently disable them ,you'd also get a bulb warning error i would have thought..
| brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275
Yes its is possible, mine went in for a service with Cam Tech Craig without them and came out with them |
Can you confirm that there are actually wires inside the headlight assembly that can be cut? I've looked inside before while changing bulbs but haven't investigated it thoroughly to determine if such wires are easily accessible. Would these wires be running from the back of the LED halo rings over to the pin connectors at the bottom corner on the back of the headlight assembly? |
I've seen LED halo light retrofit kits that can be added to the earlier l322s. I believe those have dedicated wiring added to power the angel eye halos. I just wasn't sure if the stock 2010-2012 headlights would have similar separate wiring. |
i found this which shows the wire colours [and pin numbers] for the side light..i'd cut one on the plug and see if the sides go out..
This is great, Stan! Out of curiosity, where were you able to obtain this useful information?
i've had this diagram on my laptop for a few years now, no idea where i got it from... |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
The halo/side lights are on a plug internally so, if you removed your light and looked in through the headlamp bulb hole you can see the plug from memory...
Thanks for your feedback, Craig. I didn't get a chance to inspect my headlight assembly for the wiring this evening but if you have a disassembled set that you can easily check, that'd be fantastic!
| m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 338
I read on here recently that there’s a lighting configuration specifically for Canada (and one for Scandinavia)
