Home > In Car Electronics (L322) > Rear Reversing Camera, Repair or Replace
phil67
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
As some of you are aware , I have just purchased an 09 Vogue (Pictures will be added soon promise)
I am still finding my way around the car and one of the issues so far is that the reversing camera at dusk/night is very poor /grainy, is there a way of improving this as using it in the daytime it is a lot better?
So is there a direct replacement camera or will i need a genuine range rover one?
Thanks
Post #498509 13th Dec 2018 10:20pm
Harlequin
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Mine is the same so it would be a good upgrade...
Bound to be an expert along shortly........
Post #498518 13th Dec 2018 11:35pm
rar110
Watching with interest. ______________________________
Post #498533 14th Dec 2018 7:39am
Harlequin
I found this, but seems a bit expensive, or is it just me......
https://rover.ebay.com/rover/0/0/0?mpre=ht...3411539182
Post #498534 14th Dec 2018 7:54am
kbald
Thats expensive! There are lots of threads on the replacement of the camera using ebay ones for about £7 or so. 2 ways 1 reuse the housing and fit the camera into it or 2 buy a stand alone unit. I used one like this https://www.ebay.co.uk/itm/170-Night-Visio...SwealaYUaO so you can get the angle right so you can see what you need to see.
They need to be ntsc and the picture is a bit more zoomed than the original but they are better at night and not grainy. The zoom i mention is like picture 4 on the ebay link and all the ones that have the parking lines on. All they do is put a new camera in the original housing from what i can tell for £160 wow. Current 2007 TDV8 Vogue Buckingham Blue
Post #498550 14th Dec 2018 10:14am
Harlequin
Great reply thanks! Could you let me know where you fitted it please? Into the same housing or a different location?
Cheers, Mike
Post #498650 14th Dec 2018 11:00pm
kbald
I fitted mine where the old housing was. Basically got someone to check when the position was ok and used stoing double sided tape to secure it and used automotive silicone to fill the cable hole to avoid any moisture getting in. The wiring is a bit of a hack but not difficult. Current 2007 TDV8 Vogue Buckingham Blue
Post #498651 14th Dec 2018 11:09pm
Harlequin
Thanks, much appreciated.
I have ordered the camera you suggested, and will have at it!
Post #498682 15th Dec 2018 7:54am
