![]() | Home > In Car Electronics (L322) > Rear Reversing Camera, Repair or Replace |
Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 62 ![]() ![]() ![]() |
Mine is the same so it would be a good upgrade...
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Watching with interest. ______________________________
I found this, but seems a bit expensive, or is it just me......
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Thats expensive! There are lots of threads on the replacement of the camera using ebay ones for about £7 or so. 2 ways 1 reuse the housing and fit the camera into it or 2 buy a stand alone unit. I used one like this https://www.ebay.co.uk/itm/170-Night-Visio...SwealaYUaO so you can get the angle right so you can see what you need to see.
Great reply thanks! Could you let me know where you fitted it please? Into the same housing or a different location?
I fitted mine where the old housing was. Basically got someone to check when the position was ok and used stoing double sided tape to secure it and used automotive silicone to fill the cable hole to avoid any moisture getting in. The wiring is a bit of a hack but not difficult. Current 2007 TDV8 Vogue Buckingham Blue |
Thanks, much appreciated.
