Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322
Page 2 of 6 <123456>
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I use this in my 02 Vogue. Works like a charm.
https://www.amazon.co.uk/Freebily-Wireless...TJMVEQY4GC
Post #495099 9th Nov 2018 4:44pm
DSLiverpool
United Kingdom 2012 Range Rover Autobiography Black 4.4 V8 Santorini Black
Guys quick question, some Bovees come with the cable others dont - on a 2012 FF do I need the cable? I have the ipod socket in centre console
Post #498811 16th Dec 2018 1:42pm
GGDR
Yes you do need a cable.
. Cheers, Greg
Post #498814 16th Dec 2018 2:59pm
DSLiverpool
Bought the Bovee today cant wait to try it
Post #498979 18th Dec 2018 12:06am
supershuttle
Interesting thread this, I download Spotify and other stuff to my iphone6 but can only play this back via the aux port and control is obviously on the phone. My MY2010 has the connector in the cubby box, in fact I play an old iPod through it, am I right in assuming that with the Bovee 1000 I can connect the iPhone 6 through BT and control it through the steering wheel? Geoff
Post #499053 18th Dec 2018 7:50pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
@supershuttle........I had the same issue on my 2010. The connection in the cubby box is for an older iPhone/ipod so I bought a GENUINE APPLE MD824ZM/A LIGHTNING TO 30-PIN ADAPTER FOR IPHONE/IPAD/IPOD - this allows you to use the steering wheel controls and the touchscreen.
it needs to be the original Apple lead - i tried a cheaper eBay one but it didn't work properly. 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #499074 18th Dec 2018 10:03pm
supershuttle
Coolio thanks, I assume that the phone charges when connected as well? I did have a problem with the cubby box connection and cheaper leads - iPhone6 didn't play along so what you say makes sense. You're absolutely right my ancient iPod plays and charges just fine. I assume I still need the Bovee1000 or can I get away with just the lead? Geoff
Post #499083 18th Dec 2018 11:13pm
supershuttle
Ordered lead. Geoff
Post #499087 18th Dec 2018 11:27pm
GGDR
I didn't know that using a Lightening to 30-pin adaptor would give you track skip & volume controls. If it charges it may be quite a slow charge. Let us know how you get on Geoff.
Bovee works great if you don't have any luck with the adaptor.
. Cheers, Greg
Post #499113 19th Dec 2018 9:51am
supershuttle
I've got a birthday in January and there's nothing I like more than a gadget. So if the cable alone doesn't work I'll get the Bovee,
In any event I'll keep you posted here Thumbs Up Geoff
Post #499116 19th Dec 2018 10:49am
zoso
The lightening adaptor works fine............I've had no issues with charging either. 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #499178 19th Dec 2018 3:49pm
DSLiverpool
Well my Bovee arrived from Amazon, with an AUDI cable GRRRRR I specified RR and it said on the order slip RR
Just confirming the Audi cable isnt the RR cable?
I can get it to fit easily / or do I force it
Cheers guys
Post #499316 21st Dec 2018 11:23am
supershuttle
Got the cable today. hooked it up to my iphone 6 and it works perfectly. Only one snag I can see so far that when playing Spotify downloads you can only move forward with the steering wheel controls. I'm not sure yet if it charges but the audio plays fine and there are no error messages. While I was messing I took a phone call as well also no problem. So this forum saved me the cost of a Bovee. -- Cheers Thumbs Up Geoff
Post #499352 21st Dec 2018 5:31pm
supershuttle
At the moment everything works except the charging and the controls on the steering wheel only allow you to move forward. Also it doesn’t see Spotify playlists but if you set one playing from the phone you get all the info on the display, oh you can also move backwards using the display. Geoff
Post #499598 24th Dec 2018 6:35pm
Carl 40BMI RRSC
England 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Change Junkie wrote:
You must think me a tad dim but the iPod connector is in the centre consol right.... there isn’t another one lurking somewhere?
I have a 2005 vogue se. I take it this doesn’t have an iPod connection in my RR and need to use the Aux socket?
Post #500866 7th Jan 2019 4:57pm
