![]() | Home > Technical (L405) > L405 FBH Telestart Receiver Fob Pairing - Solved |
| Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 798
I've answered my own questions, and a few more, by reading the Webasto manual (link below).
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 965
These are the instructions I followed per page 22, but no joy in pairing on my L405, programmed a few using the same method on my L322's no problem at all. |
I suppose it could be a problem with the fob? I’ll let you know how I get on when my new fob arrives. MY23 D350 HSE
| Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409
Errrr....why not just leave the heating fob with your main fob/keys ? |
.....because I dislike carrying around unnecessary items in my pocket.
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268
Sorry for the delayed response.
| Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673
Does this work for the L405 Eberspacer type remotes then?
| PLOG Member Since: 19 Nov 2018 Location: Teesside Posts: 25
Charles89, can you confirm you used the method from the first page of this thread? i.e. pulled the yellow 20A fuse from the smaller fuse box in the rear loadspace area and this worked okay? Does your remote look like the one pictured above? I’m still having trouble, I even bought two different remotes and no joy with either. If I know it definitely works, I’ll persist, but nothing’s happening each time. Any help/info is appreciated. |
Yes indeed. However, if your FBH is not coded to have remote start then the module for the antenna won't be active. Do you have an IID Tool to check the coding? |
I don’t, Charles, but I do have the build/spec sheet for my car and it says “park heat with remote”, so I’m assuming this means it does have the ability. Unless I’m mistaken? |
Update. I bought a new fob (like the one in the photo above but with the Jaguar logo) from eBay for £45.
I too have now successfully paired my fob |
Yes that means you have the ability yes |
| All times are GMT |
