Home > Technical (L322) > Replacing the wiper mechanism.
Danbhardy
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Is this an easy job?
Something snapped in mine today and I need to replace the whole lot apparently!
Post #499388 21st Dec 2018 10:03pm
Danbhardy
Has no-one done this?
Post #499678 26th Dec 2018 12:09pm
if you mean the front wiper mechanism then this is the first i've heard of it breaking...i might be wrong so do a search ..
Post #499679 26th Dec 2018 12:15pm
JWL
Must be the time of year Sad mine broke at the bottom of the passenger side arm just before Christmas.
It took a specialist 2 hours to replace the entire mechanism.
Post #500346 2nd Jan 2019 4:33pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
If it's the linkage arm it depends if it's actually broken or just dropped off the knuckle, if it's intact you can swap it so opposite ends are now on the knuckles. Did mine 12 months ago. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #500385 2nd Jan 2019 10:00pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Re: Replacing the wiper mechanism.
Hope this helps you Fella
Did both our cars last summer ( just in case ready for winter ) - takes about 1 hour.
You do need to puller to take off the wiper blade arms - when you re install INSURE YOU PUT GREASE ON THE TREADS - LR factory did not put grease on the spindles - Aluminum & Steel will bind over time !
Take your time when putting the wiper arms back on - threads are thin and you can strip them if your not careful.
The cars are 12 year plates and wipers are so important - especially in the winter - its worth replacing these every 5 years before they pack up - don't want them packing up on a airport run !
Post #500439 3rd Jan 2019 5:04pm
