Home > Maintenance & Mods (L322) > How to change bulbs in the roof courtesy lights
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I use the cree in those Wink like mini spotlights Similar to these http://www.ebay.co.uk/itm/2x-CREE-W5W-T10-...SwEeFVC3sr _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #452019 25th Sep 2017 1:31pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
For anyone who's found their LED bulbs won't fit through the hole in the back of roof light panel, try fitting the bulb from the front after taking the lens cover off & then fit the bulb holder to the back of the bulb.
It's a slight faff, but solves the problem if the bulb is slightly too large in diameter.
Doesn't help for the main centre light when the bulb is just too long - lol Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #492080 13th Oct 2018 11:36am
p38arover
Australia
I ended up enlarging the holes with a taper reamer like this. I had it in my electronics toolkit..
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #492087 13th Oct 2018 12:15pm
rar110
Is there a trick to removing the rear map area ding light assembly? I have the front map light assembly out.
I have tried using a screw driver to push on the edge doing plates. But can’t seem to get it out. ______________________________
Post #500047 30th Dec 2018 8:32am
rar110
Disregard. I eventually got it out.
Interesting, as indicated by P38A (Ron) above, the hole for the middle bulb front and back seats map light assembly was smaller. It was too small for the LED bulb. I didnt have the tool referred to by Ron, so drilled it out with 13mm drill bit. Problem solved. ______________________________
Post #500051 30th Dec 2018 9:28am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
There is a good video on YouTube where the guy changes all interior lights to LED, its next on my list of things to do
Post #500054 30th Dec 2018 9:58am
rar110
Ive been putting off this job for about 18mths thinking it was going to be difficult.
It wasn't very hard at all. I did break one of the upper tail light lenses retaining clips. I just stuck it back on with a dot of silicone.
I watched a YouTube vid on removing the front map lamp assembly. Popping off the squarish panel behind the light allows you to get your hand in behind the lamp assembly and push it out quite easily. The rear seat map light assembly wasn't as easy, but I got there in the end.
We go camping a bit and the cargo area is opened quite often. Im amazed at how much heat the incandescent bulb emit, which is an indication of how much power they draw. There 15 of these bulbs around the car, and most of them light up when you open a door. So this should help save the battery a bit. ______________________________
Post #500058 30th Dec 2018 10:24am
