Home > For Sale & Wanted > [FOUND] Polystyrene Mount For L405 Spacesaver Wheel
JCW
I believe the L405 spacesaver spare wheel requires a polystyrene section fitted underneath which a full size spare doesn't need.
If anyone has one surplus to requirement, I'd be interested.
Thanks
Edit - now found one, thanks to tb10
Post #500193 31st Dec 2018 3:43pm
p38arover
Australia
If a full size spare will fit, why get a space saver? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #500232 1st Jan 2019 9:24am
JCW
Its a temporary measure until a fifth full size 2018 SVAutobiography wheel is sourced Thumbs Up
Post #500233 1st Jan 2019 9:29am
i have 21'' wheels/tyres on mine and have a SS and i put some polystyrene underneath it from some old led TV packing..
Post #500235 1st Jan 2019 9:35am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I think I have one which I don’t need. PM me Thumbs Up
Post #500236 1st Jan 2019 9:54am
Off topic, but I'd far rather have an odd (non-matching) wheel the same size, than a space saver - at least that way you can travel as far and as fast as you would otherwise. Maybe it's just because I do long fast runs at times of day when stopping to get a puncture repaired just isn't possible.....
It can't look any worse than having a space saver fitted.
Post #500237 1st Jan 2019 10:29am
p38arover
Australia
I should have phrased is as "why would one have a space saver wheel if a full size wheel will fit?" Is a space save standard factory fit net these days? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #500287 2nd Jan 2019 3:48am
Yes - you can spec a full size one for not much money - IIRC a couple of hundred pounds, but otherwise you get a space saver - which I guess at best could be marketed as a weight saver as once you chuck in a lump of polystyrene you save zero space.....
Post #500292 2nd Jan 2019 8:55am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Re: [Wanted] Polystyrene Mount For L405 Spacesaver Wheel
Hi, I will have one in a week or two (possibly less) as I am currently in the process of buying a full size spare, which should arrive next week some time. Just need to put on a tyre and TPMS sensor, and the polystyrene (and my space saver) will be surplus to requirements. Not sure if it would survive a delivery experience though!
Post #500820 7th Jan 2019 1:32am
JCW
Thanks nubbin, looks like I'm sorted now thanks to tb10 Thumbs Up
Post #501264 12th Jan 2019 8:44am
