![]() | Home > Technical (L322) > Suspension query and oddity...... |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
I don't know what your thinking is but the suspension settings has no influence on tyre pressures.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
double check the tyre pressures again...it could be the valve is blocked and giving you a false reading.. |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
As above two fronts are at 33 psi and the rears 36 psi checked with two different pressure tests and also on his air compressor.... so it's not tyre pressure related |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
I believe this is physically possible (if not technically!)
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Is the care on an incline and self-levelling?
Or does the car "think" it is on an incline ?
This was in our garage which is as flat and level as any concrete slab would be ![]() It's interesting the two corners pushing down hardest so to speak are the ones with the new sensors which are genuine parts. ![]() |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 92 ![]() ![]() ![]() |
+1 Joe 90, your analogy is sound.
Aligned as much as possible within the LR tolerances as you can never get it perfect. 2011 4.4 TDV8 Autobiography |
