Home > Technical (L322) > Suspension query and oddity...... |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
I don't know what your thinking is but the suspension settings has no influence on tyre pressures.
2nd Jan 2019 3:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
double check the tyre pressures again...it could be the valve is blocked and giving you a false reading.. |
2nd Jan 2019 3:17pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
As above two fronts are at 33 psi and the rears 36 psi checked with two different pressure tests and also on his air compressor.... so it's not tyre pressure related
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
I believe this is physically possible (if not technically!)
2nd Jan 2019 4:00pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Is the care on an incline and self-levelling?
2nd Jan 2019 4:36pm |
Or does the car "think" it is on an incline ?
2nd Jan 2019 6:51pm |
This was in our garage which is as flat and level as any concrete slab would be It's interesting the two corners pushing down hardest so to speak are the ones with the new sensors which are genuine parts. 2011 4.4 TDV8 Autobiography |
2nd Jan 2019 7:14pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
+1 Joe 90, your analogy is sound.
2nd Jan 2019 7:46pm |
Aligned as much as possible within the LR tolerances as you can never get it perfect. 2011 4.4 TDV8 Autobiography |
2nd Jan 2019 8:13pm |
