Home > Maintenance & Mods (L322) > Issue with Deployable Side Steps |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
DJM911
8th Jan 2019 1:45pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
The step would redeploy if it sensed an obstruction so maybe a position sensor is FUBAR or there is an obstruction preventing it reaching its "park" position? Bish.
8th Jan 2019 2:00pm |
DJM911
8th Jan 2019 4:23pm |
DJM911 Member Since: 05 Mar 2018 Location: Northern Ireland Posts: 78 |
Unnecessary quote removed
8th Jan 2019 7:08pm |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 81 |
Hi there
24th Feb 2020 4:53pm |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 |
i also have the exact same problem as OP.
26th Feb 2020 1:46pm |
sumshiftyguy Member Since: 13 Mar 2020 Location: London Posts: 36 |
I too have this exact same problem. I have tried lubricating with everything I can see with wd40 but not sure if it's helping. The problem was intermittent but becoming more frequent.
13th Mar 2020 12:14am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
WD40 isn't a lubricant! I use a silicone lubricant on mine. 2010 4.4 TDV8 Vogue SE |
13th Mar 2020 12:37am |
Wd40 is in fact a lubricant and penetrating oil. But I take your point and will try some silicone lubricant, if that's worked for you. Thanks! |
13th Mar 2020 8:49am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
a google search comes up with this,
13th Mar 2020 9:45am |
Technically, WD40 seem to also do a silicone lubricant...
13th Mar 2020 11:00am |
yeah they do quite a bit now.
13th Mar 2020 12:31pm |
Great, thanks. Think I'll give GT85 a go then!
13th Mar 2020 12:56pm |
I was on about WD40 range been quite big..
13th Mar 2020 1:21pm |
