|  | Home > Maintenance & Mods (L322) > Issue with Deployable Side Steps |
| EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361      | DJM911
|  8th Jan 2019 12:45pm |
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344    | The step would redeploy if it sensed an obstruction so maybe a position sensor is FUBAR or there is an obstruction preventing it reaching its "park" position? Bish.
|  8th Jan 2019 1:00pm |
|  8th Jan 2019 3:23pm |
| DJM911 Member Since: 05 Mar 2018 Location: Northern Ireland Posts: 78      | Unnecessary quote removed
|  8th Jan 2019 6:08pm |
| muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 95      |
 Hi there
|  24th Feb 2020 3:53pm |
| MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140      | i also have the exact same problem as OP.
|  26th Feb 2020 12:46pm |
| sumshiftyguy Member Since: 12 Mar 2020 Location: London Posts: 36      | I too have this exact same problem. I have tried lubricating with everything I can see with wd40 but not sure if it's helping. The problem was intermittent but becoming more frequent.
|  12th Mar 2020 11:14pm |
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386      | WD40 isn't a lubricant! I use a silicone lubricant on mine. 2010 4.4 TDV8 Vogue SE | ||
|  12th Mar 2020 11:37pm |
| sumshiftyguy Member Since: 12 Mar 2020 Location: London Posts: 36      | Wd40 is in fact a lubricant and penetrating oil. But I take your point and will try some silicone lubricant, if that's worked for you. Thanks! | ||
|  13th Mar 2020 7:49am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | a google search comes up with this,
|  13th Mar 2020 8:45am |
| sumshiftyguy Member Since: 12 Mar 2020 Location: London Posts: 36      | Technically, WD40 seem to also do a silicone lubricant...
|  13th Mar 2020 10:00am |
| MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140      | yeah they do quite a bit now.
|  13th Mar 2020 11:31am |
| sumshiftyguy Member Since: 12 Mar 2020 Location: London Posts: 36      | Great, thanks. Think I'll give GT85 a go then!
|  13th Mar 2020 11:56am |
| MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140      | I was on about WD40 range been quite big..
|  13th Mar 2020 12:21pm |
| Posting Rules
