![]() | Home > Technical (L322) > No heat from vents FIXED |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Also you dont need to take the dash out to get at the blend motors just the glove box and the finishing panel on the drivers side |
| Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11
Update
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
No, petrols do not come with FBH as std - it is an option. I have it on my v8 petrol autobiography.
| Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 85
As said my valve suffered from swollen valve seats, for interest it would be nice if you could report back if that was the problem for you. 2006 Supercharged |
Ian928
Thank you, this is just for history for others to see. If the seats have increased in size the valve will be stuck in the middle position, maybe this is what the mechanic is reporting. 2006 Supercharged |
| Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8
I have the same problem on my 2005 supercharged. Where is the valve located and wtf is an FBH? 🤔😂 |
FBH = fuel burning heater, I’m sure someone else will advise you of where it is situated |
Cheers fella. I don’t have one of those so can’t be that valve then. |
Read my 1st post & go from there |
Glad you have it sorted and for reference mine was seized ie no movement can't comment on the seals though afraid |
Fixed |
| All times are GMT |
