|  | Home > Technical (L322) > No heat from vents FIXED |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287      | Also you dont need to take the dash out to get at the blend motors just the glove box and the finishing panel on the drivers side | ||
|  9th Dec 2018 6:28pm |
| Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11    | Update
|  10th Jan 2019 7:16am |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284      | No, petrols do not come with FBH as std - it is an option. I have it on my v8 petrol autobiography.
|  10th Jan 2019 8:16am |
| Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 85      | As said my valve suffered from swollen valve seats, for interest it would be nice if you could report back if that was the problem for you. 2006 Supercharged | ||
|  10th Jan 2019 8:40am |
| Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11    | Ian928
|  10th Jan 2019 10:01am |
| Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 85      | Thank you, this is just for history for others to see. If the seats have increased in size the valve will be stuck in the middle position, maybe this is what the mechanic is reporting. 2006 Supercharged | ||
|  10th Jan 2019 4:59pm |
| Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8      | I have the same problem on my 2005 supercharged. Where is the valve located and wtf is an FBH? 🤔😂 | ||
|  10th Jan 2019 7:29pm |
| Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11    | FBH = fuel burning heater, I’m sure someone else will advise you of where it is situated | ||
|  10th Jan 2019 7:33pm |
| Carl 40BMI RRSC Member Since: 02 Jan 2019 Location: Coventry Posts: 8      | Cheers fella. I don’t have one of those so can’t be that valve then. | ||
|  10th Jan 2019 7:35pm |
| Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11    | Read my 1st post & go from there | ||
|  10th Jan 2019 7:38pm |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287      | Glad you have it sorted and for reference mine was seized ie no movement can't comment on the seals though afraid | ||
|  11th Jan 2019 7:59am |
| Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11    | Fixed   | ||||||||||
|  11th Jan 2019 6:03pm |
| Posting Rules
 It was the valve for the fbh See pic Part no. is on the box
