![]() | Home > Orders (L405) > Engine choice |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
SDV6 All LR cars from 1984
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
I'm very happy with the 5.0SC, having come from a 322 TDV8. It's smooth and refined when you want to drive it gently, but with a feeling of latent power on hand if required. Most of my driving is out of town, I use higher rolling resistance tyres (Goodyear Duratrac 255/55R20) in winter and do a certain amount of off road and towing, average since March 18 is showing at 24.5mpg using almost exclusively Shell V Power. Range on that basis is 400 - 450 miles. As the speedo over-reads the real figure will be a bit worse. One is in filling stations a lot, and of course town work will be much worse. The diesel is much better for towing, I've seen 4mpg on 'current use' when towing a light trailer up a rough track, in high ratio. If you do lots of heavy towing the diesel is still the better choice, unless you have a lot of town use which would not be suited to the emission control equipment.
Freddy Bear Member Since: 10 Jan 2019 Location: London Posts: 161 ![]() ![]() |
Thanks Chalky - could you say a few words about why you recommend the SDV6?
Freddy
Thanks Chalky, that is very helpful.
Montys 4x4 Member Since: 23 Dec 2014 Location: Suffolk Posts: 70 ![]() ![]() ![]() |
Hi, now the oil dilution issue and 4,500 miles oil service frequency has been sorted in the TDV6 3.0D by the software update last Oct/Nov I would again give the combination of Performance and fuel economy a thumbs up. I do not do town driving in my RR and sit at an average of 48 to 56 mph in todays commuting traffic and average mpg is always showing 40 to 41 mpg. the front end is a little lighter and the engine block is further back than the V8 D so handling in the bends is less ponderous biggest downside is that they fit smaller brakes discs to the TDV6 and its so noticeable if you've had a 4.4 D or something like a Porsche Cayenne. I just don't know why they do it, its nearly the same weight as the RR V8 diesel just about as quick to 60 but the designers think the TDV6 doesn't need to stop as quickly. My Bentley Conti GT has front discs nearly a size and a half bigger at the front. So yes it would be hard to justify another engine other than the TDV6 and if the latest FFRR now comes with the RRS SDV6 power hike then a no brainer.
Thanks Paul.
Paul
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
I went one better and got the V6 Hybrid |
On tank size, it was reduced when AdBlue started, my assumption therefore is that it is to make space (either literally or in weight terms) for the AdBlue tank and its contents. Only Range Rovers since 1988 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
The V8 Diesel not only has better brakes but also has a better front suspension set up, if you enjoy spirited driving the difference is very noticeable.
Every RR, whatever engine, is nice to drive when everything is working.
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 131 ![]() ![]() |
A very interesting thread as I am going through the same issue. I have owned my L405 SDV8 for just over 4 years now and want to change it. I feel strongly that the time is right to go back to petrol and I am trying to convince myself that a 5.0 S/C is the correct car for me. I do tow, but not so much as to be an issue which engine I use, other than I would not go down to a TDV6. I am going to ask my dealer if he can get a 5.0 S/C from JLR for me to trial. Looking at the current woes that JLR are experiencing, I think they will have to hasten the engine/model changes though. If diesel is the fuel of the devil, not everyone can stomach the consumption of big petrol engines. To be completely honest, the Range Rover market place only really expanded as much as it has after "proper" diesel engines were designed. I bought my first RR back in 1981 and back them most people would not go near a V8 Range Rover because of the fuel consumption. Land Rover are in big trouble unless they can offer their cars with a seriously efficient engine range, and PHEV is not it imho. 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
Diesel is no more the fuel of the devil today than petrol was when Gordon Brown changed the taxation system in favour of diesel. I think we are all getting caught up in the hysteria of particulate pollution from what are very clean cars, whilst millions of builders, farmers, taxi drivers etc, chug around in filthy older diesel vehicles without a hint of concern. It is with these older diesels that the problems lie, not the high efficiency modern diesel systems that comply with Euro 6 regulations, which are allowed into ultra-low emission zones - proof of their relative cleanliness.
