Home > Maintenance & Mods (L322) > 6 Pot Brembos -Pads and measuring discs (thickness) - tips?
Page 1 of 3 123>
GGDR
Hi team,
Bought a micrometer to measure my discs. It's got a 25mm capacity and been sat in a drawer for a few weeks. Today went to measure and found it won't fit over my discs. Rolling Eyes
Shoulda checked I guess!
Anyone know a fairly accurate way to measure without a micrometer?
Wanted to do it today so ordering a bigger micrometer will take a day or two...
Cheers!
. Cheers, Greg
Post #501291 12th Jan 2019 3:32pm
GGDR
Found it
Now I just need two x one euro coins....
(Method #2 will work, I've got callipers)
. Cheers, Greg
Post #501292 12th Jan 2019 3:37pm
Baltic Blue
£20 if you have got a local Halfords store ?
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #501293 12th Jan 2019 3:46pm
GGDR
Just to save somebody looking it up, the workshop manual says:
At 4 points around disc, measure disc thickness using a micrometer; renew disc if less than service limit or if variation is exceeded: Disc thickness, NEW 34 mm, Service limit 31 mm. Thickness variation maximum = 0.01 mm
This is for Brembo 6-pot fronts (2011 Workshop Manual). Cheers, Greg
Post #501294 12th Jan 2019 3:46pm
GGDR
Thanks Mike, terrible of Halfords to show that. It's the complete incorrect way to check a disc.
In the video, you may see method #2 where he uses two coins, then subtracts the coins. You need to measure past the lip which every disc will have unless it's brand new.
Also I should have checked the manual before I ordered a micrometer. Banging Head
Yes I have a callipers. Thumbs Up Thumbs Up
. Cheers, Greg
Post #501295 12th Jan 2019 3:50pm
rjff
Try searching for brake disc calipers.
ebay or web brings up plenty.
They have a deep throat style. (don't try searching that with SWMBO looking over your shoulder)
Fairly inexpensive and will let you get closer to the hub. Micrometers for that job are expensive Cheers
Richard
Gap IIDBT (learning but happy to help)
Post #501300 12th Jan 2019 4:27pm
nino_nino
Greg, I use Vernier calipers and two coins to check thickness. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #501302 12th Jan 2019 4:35pm
rjff
I use button magnets instead of coins where they stick, not neccessarily on car discs, helps without having to hold them. Only downside is that they don't give indications of thickness at the bottom of scores on a disc etc. That needs point tips on a suitable micrometer but if they are that bad, then you probably need to do something along the lines of further work. Cheers
Richard
Post #501305 12th Jan 2019 4:56pm
Baltic Blue
You could check the rears instead Greg, assuming it’s not raining down there, like it is up here. Rolling with laughter
New 20mm
Service Limit 18 mm.
Post #501306 12th Jan 2019 4:58pm
GGDR
Thanks guys.
Just started raining here but managed to get the wheel back on as it started.
Just did it using the coins method.... A bit of a balancing act.
So I LOVE this idea:
Thank you rjff
An instructor-level mechanic taught me to use micrometer. But I didn't know you could get brake disc callipers, will have a look.
Results: NS measures 33.2mm (was also taught to measure NS, prizes for guessing why)
Needs pads but discs not too bad at 33% allowable wear.
Regarding pad vs rotor wear - My discs and pads were both done around two years ago before I bought it. Based on the 33.2mm measurement today, I'd say I could get another set of pads use, then replace both next time. Making it a sort of 2 to 1 pad to disc wear ratio if that makes sense. Is this typical?
What's the consensus guys, shall I leave the discs?
. Cheers, Greg
Post #501311 12th Jan 2019 5:18pm
rjff
Greg
Glad you like the idea. If you search for calipers, try brake disc vernier calipers. Cheers
Richard
Post #501372 12th Jan 2019 11:37pm
kds2
England 2003 Range Rover Vogue Td6 Adriatic Blue
Had digital vernier calipers for less than £10 in Lidl of late, plenty good enough for checking discs.
Post #501375 13th Jan 2019 12:54am
m@ttsFF
I’d leave the discs until next pad change 4.2 SC
Post #501389 13th Jan 2019 11:32am
nino_nino
is there good machine shop in your neighborhood, Greg ? 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #501398 13th Jan 2019 12:56pm
GGDR
Why's that Nino?
. Cheers, Greg
Post #501402 13th Jan 2019 1:19pm
Page 1 of 3 123>
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
