![]() | Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm? |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
It is not that difficult, just need to remember to torque the bolts up with the car at normal ride height with weight on the front wheels. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
The difficult part on that assembly is getting the ball joint out of the hub, but if you can split the arm from the ball joint without damaging the rubber then changing the arm is easy.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
I only replaced the bushes - sort of. They didn't look cracked but there was a 3-5mm gap between the bump-stop at the arm end and the centre flat when new bushes don't have a gap. Sure enough the old bushes were found to be very cracked and floating when removed.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
Do those ball joints take a good amount of wear?
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Changing the control arm is not difficult, I did the front passenger side in summer and learnt alot.
I think Stan wikified my attempt.... |
I’ve got to do the ballpoint on mine at the weekend so will try and do a decent write up when I do it for future reference. |
Thanks guys.
You need to get the bush aligned properly and will need a tool to wind it out and back in again if you are just swapping the bush. TbH if you can break the taper on the ball joint end without bu**ering the rubber then it’s a damn site easier to swap the whole arm, they aren’t that dear.
Ok thanks Mark, I'm still getting my head around it....
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
The next one of these I do I will def release driveshaft gaiter and roll it back out of the way cover with wet towel and heat the |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
apparently, these are the handy for getting the ball joint bolts out.
Ball joint bolts are the easy bit just don
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
In my experience, absolutely worth their weight in gold ![]() Over the years, these Irwin's have shifted many a (very) rusty bolt on our RR's. Expensive for what they are but they don't wear out and very often the only thing that will work. |
