![]() | Home > Technical (L322) > Oil leak |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Diagnosis in. Oil cooler gaskets (I was dreading it might have been a turbo |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Dr Rob, there is a common EGR fault code....
The code is: P040D-00 (2F) Exhaust Gas Recirculation Temperature Sensor A - circuit high
OK, thanks. Will ask....
If you are getting that error code it's a probe (sensor) around £75.
(Sorry about the typo)
Looks like it’s chepaer and easier to get a main dealer to change out the NS sensor.....who’d have thought that |
I'm going to get the EGRs done anyway (only money!)
EGRs not being replaced. A vacuum pipe was found to be disconnected which probably threw up the intermittent EGR fault error codes on the diagnostic.....
L322 Newbie Member Since: 22 Mar 2017 Location: Boldon, Tyne & Wear, UK Posts: 26 ![]() ![]() ![]() |
Hi all,
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Steve what was your main oil cooler leak? Cooler itself or gasket? How did it show up on the car (i.e where did you see the oil)? Did you fix it yourself and if so how difficult was it? What age and mileage is your FF?
