Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm?
Page 2 of 5 <12345>
The thing is 2 or 3 parts, the ball joint which is in a cassette held in by the 2 torx bolts shown in that pic, the arm which comes with the big bush pressed in and you can buy the big bush separately.
Ball joint
Arm
Don’t go thinking you take those 2 bolts out and can remove the ball joint cassette.... Rolling with laughter
That’s the bit which is a PItA to get out. If you are releasing this end then take off the single nut in the middle and crack the taper with a splitter.
That will then leave you just the one bolt through the big bush end. There is nothing that can't be fixed with a hammer😜😜
Post #501599 15th Jan 2019 8:41am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
if the bolts that secure the strut to the hub are turning ok (mine were siezed solid) then i reckon removing the hub is the best way to replec the thr bottom ball joint.
i bought a used hub off ebay for £30 to practise on since i didnt want the car in bits on drive whilst i figured out how to do it. it's easy to get the torx bolts out with the hub on the bench as the Cv joint is not in the way. they came out with an impact driver but of course you can use heat or even take it to someone else for them to do it. you will not lose the battle with those bolts if you have the hub on the bench!
next, you just use a chisel or drift to bash the ball joint out. again, you will win this contest easily as you can hit the ball joint direct without the cv in the way.
i dont recommend moog brand ball joints
Post #501614 15th Jan 2019 10:52am
GGDR
Thanks Mark.
Dan just said:
Quote:
If they are the lower arms £48.00 each come with ball joint on arm Prices are for OEM delphi units.
So pretty reasonable and so now I'm thinking about blow torches.....
EDIT: this is wrong, see two posts down
. Cheers, Greg
Post #501623 15th Jan 2019 12:01pm
GraemeS
Australia
The arm described as the lower has the ball-joint fitted and its taper fits into the hub. The rear-wards one with the larger replaceable bush is the upper, and as shown in the earlier pictures its ball-joint taper fits into the arm, not the hub and its ball-joint is a separately purchased part.
Post #501627 15th Jan 2019 12:22pm
GGDR
Correction just in from Dan:
Quote:
£72.00 each + ball joint £38.00 each – Delphi arms and Genuine Ball joints
...which marries up with what you are saying Graeme.
. Cheers, Greg
Post #501628 15th Jan 2019 12:23pm
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
ball joint
i havent done the lower balljoint on an l322 yet-i have done similar though,an e53 x5
had to remove complete hub,blowtorch with mapgas for max heat around it in a vice and use an electric breaker to disloge it
would be fine in a nice dry climate but a 10 year old uk car-not a hope it was gonna be easy
my air chisel/punch[normally a great help] wouldnt look at it
reading the forums its a known pita of a job
Post #501631 15th Jan 2019 12:33pm
GGDR
Ok I'm back to thinking just changing the bush is the way to go.
But Dan's just said:
Quote:
(Bush is) only available as part of the arm.
Anyone know where I can get the bush on it's own?
Looks so easy to get to, just right there with the wheel turned:
 Cheers, Greg
Post #501634 15th Jan 2019 1:02pm
dexion7
you will need the arm off to change the bush which you can get from ebay. not worth the hasle IMHO - just replace the whole arm.
get one of these to release the ball joint.
eBay Item No. 142146541517
if you use a forky type of tool for splitting the ball joint taper you will furk the ball joint and it's boot but if you use this tool with a piece of aluminium on the top of the ball joint stud (to prevent the tool damaging the ball stud's thread) it will be re-useable.
Post #501684 15th Jan 2019 5:41pm
dexion7
BTW
i believe that the OEM arms were made by Lemforder?
Post #501685 15th Jan 2019 5:41pm
kbald
Bushes available from advanced factors here https://www.advancedfactors.co.uk/front-su...-287-c.asp
Easy to do wih a press and the right kit, if you dont have that stuff the saving made on the cost of the arms could cover the cost of some equipment, if not buy the arm with the bush in. Ball joint a pain to split as can't get a splitter in easily when in situe. A bit of hammmering and a wiggle of the wheel should help release it though. Current 2007 TDV8 Vogue Buckingham Blue
Post #501691 15th Jan 2019 6:21pm
Oem arms are Lemforder but Delphi will do fine.
Don’t bother with just the bush, as said the arm will have to come off to swap it anyway. The bush used to ba available separately, I had one as a paperweight on my desk and never fitted it. There is nothing that can't be fixed with a hammer😜😜
Post #501706 15th Jan 2019 7:18pm
GraemeS
Australia
As I stated earlier, I R&R'd my 2nd side bush with a bush removal & refitting kit that was already on hand but the 10T press for the 1st side bush was much easier.
Post #501723 15th Jan 2019 9:03pm
GGDR
Interestingly it's called the upper arm on the Advanced Factors diagram:
So now I'm not sure which of Dan's prices (up a bit) is right?
. Cheers, Greg
Post #501751 15th Jan 2019 11:00pm
GGDR
I'm also now seeing the ball joint facing down on that diagram.
For some reason I thought it was facing up and into the hub assembly.
So if I can get these two bolts off (and the bush end bolt) the arm will come away with the ball joint (still together) then I can discard both and I can replace both with new?
Meaning there is no taper to break, only the two rusty bolts?
 Cheers, Greg
Post #501752 15th Jan 2019 11:02pm
GGDR
Ok I found this:
Helps to see the guy do it and his voice over is pretty helpful too.
Check out those wheels btw!
. Cheers, Greg
Post #501758 16th Jan 2019 12:11am
Page 2 of 5 <12345>
