Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 12 of 15 <123 ... 1112 131415>
Hopefully these links will work Greg Neutral
https://www.facebook.com/1282263659/videos...EfpmewoDcy
https://www.facebook.com/1282263659/videos...sErYj2Iq0H
Post #498668 15th Dec 2018 12:49am
GGDR
doesn't work...
. Cheers, Greg
Post #498678 15th Dec 2018 7:29am
Baltic Blue
Just proves what a good job you did Greg. Thumbs Up
Merry Xmas.
Post #498720 15th Dec 2018 1:17pm
DrRob
Is there a condensed version of this with a step by step guide of how to diagnose with an IID? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #501635 15th Jan 2019 1:14pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
IID diagnoses this for you -- I have a persistent fault code as the title of the thread -- will not clear -- if your IID isn't showing the code then it's unlikely you don't have the problem Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #501636 15th Jan 2019 1:16pm
DrRob
Cool. From reading the whole thread, it seems the best route is to pay an MD / Rovertune to do it...? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501638 15th Jan 2019 1:18pm
GGDR
No sorry haven't done my write up yet
As Bushy said it'll come up as the error:
. Cheers, Greg
Post #501641 15th Jan 2019 1:33pm
GGDR
I don't know about changing something that aint broke,
personally disturbing things that don't need to be disturbed can add an element of error
Just my view.
. Cheers, Greg
Post #501642 15th Jan 2019 1:34pm
DrRob
Thanks and agreed Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501644 15th Jan 2019 1:41pm
GGDR
I will be doing a write up when I get a chance.
If anyone wants to do this job themselves in the meantime, please PM me.
With the right prep and exactly the right tools it could take as little as 4 hours
Getting the exact tools was a trial and error which is why it took many weekends.
On that note I have the special socket - I got the Laser Tools version which is six sided not twelve sided like the JLR.
https://www.lasertools.co.uk/product/6850
It's no longer needed so happy to sell it for less that ordering a new one.
PM me for either.
. Cheers, Greg
Post #501646 15th Jan 2019 1:52pm
DrRob
I defo have the code (new IID working Thumbs Up ) but can’t work out if I should get it done or not....by Rovertune Whistle 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #502207 20th Jan 2019 1:40pm
Baltic Blue
Rob,
If it helps, I have had this Fault code ever since I bought an iid (2years), so presumably it was their before.
My local indi Range Rover specialist isn’t willing to give me a quote because he says it is impossible to say how long it will take.
He did tell me that one effect is that it prevents him ever being able to activate a “ Forced “ DPF regen., but otherwise I can’t see any other benefits.
I am watching Greg’s reports with interest to see if he now gets less DPF soot level problems.
Post #502218 20th Jan 2019 3:09pm
GGDR
Well I passed the new, stricter MOT smoke test around a week ago. I was worried. I was also worried they would see my DPF that has been cut out, cleaned and refitted around a year ago. But that was no bother, they said fine.
This is my DPF on the floor a while back, you can see where the joint clamps ended up:
http://www.fullfatrr.com/gallery/albums/us...G_0164.JPG
Back to the sensor: After a few months now, I don't think changing the sensor has made a difference positive or negative to the DPF situation. It is satisfying not to see the error. But a bit of a downer it didn't improve DPF performance. At least it gives a result in terms of process of elimination, for example I have read about throttle bodies playing up, might check that out next. Otherwise I'll resign myself to doing a DPF regen regularly.
I did work out something interesting, regens seem to align with fuel tanks, it seems to be one regeneration per tank, which is an interesting correlation - that is quite logical I guess.
Fuel usage to miles: Sometimes I get 300 miles a tank (all city) I've had 460 miles with mixed city, mostly motorway. Which seems about normal. I know some motorway guys have reported over 500 miles.
This tank I'm on now - I seem to getting rubbish fuel economy. Half a tank's only got me 100 miles so far. Cold weather maybe? Zero motorway and a short 2 miles to work, 2 miles home. It's barely warm by then.
I love this engine, it's absolutely epic. But it's not great for my driving pattern. If the cost to me is monthly regeneration runs, I'm absolutely fine with that. The 4.4's totally worth it.
. Cheers, Greg
Post #502246 20th Jan 2019 9:54pm
GGDR
Based on learnings above and throughout this thread,
I've done a 'clean' write-up / wiki for how to change the sensor here:
https://www.fullfatrr.com/forum/post504541.html#504541
. Cheers, Greg
Post #504542 9th Feb 2019 1:40am
Mr Tee
What a thread, just activated my IID, loads of faults cleared, but I have this error code, don’t suppose anyone has had this done by pentland ?
Post #530434 9th Oct 2019 7:24pm
